11-11-2018, 10:32 AM | #1 |
Rep 104
Carly transmission reset
Hi all has anyone reset the transmission adaptions on a bmw f30 using the Carly app did it make a difference and for the better or the worse I have just recently bought my car and just wondered if it was worth doing so it can " learn" my driving style rather than the last drivers way of driving.
Thanks Matt. |
11-11-2018, 10:57 AM | #2 | ||
Rep 15,858
My understanding from ZF data, resetting gearbox adaptation values require a specific 'teach-in' process, which include a set driving sequence with the laptop linked to read values, until the new values are all logged. Any values left at 'zero' in the teach-in process means it isn't complete. This is the sort of comment on how important it is, to relearn the values. BTW, this is not describing driver adaptations, but GEARBOX adaptations. Quote:
11-11-2018, 11:05 AM | #3 |
Eh? Team member
514
Rep 1,190
Drives: F31 335i
I'm personally not convinced that there's any driver "learning" at all.
11-11-2018, 11:28 AM | #5 | |
Rep 15,858
Driver influenced adaptations are only one function of 'continuous' gearbox adaptation. Condition/environment adaptations (bends, hills, etc.) are just as active as the driver influenced adaptations, both working on the fly. The gearbox adapts to driver inputs, such as how we use the brakes, (brake evaluation), throttle (kick-fast) and steering inputs (fast reactions). |
Wills28654.50 |
11-11-2018, 01:32 PM | #6 |
Rep 121
I've tried it with my Carly. I'm not familiar with any of the technical specs of the transmission but I did notice a difference..a big difference.
Over the last couple months my car started to feel sluggish, the reset made my car feel normal again. |
11-11-2018, 02:24 PM | #7 |
Rep 104
Good to know nothing bad happened I may give mine ago I wonder how long the car is in the learning mode for though
11-11-2018, 03:23 PM | #9 | ||
Rep 15,858
Next day it all starts again, drives off the same each day, until you set up the style you currently drive. It is not remembering the way you drove the day before and then taking days to re-adapt to something different. That's not the way adaptation works. As I've already said, gearbox adaptation and values is something completely different, requires specific re-learn/teach-in procedures. |
Wills28654.50 |
11-11-2018, 03:28 PM | #10 | |
Rep 709
11-11-2018, 03:33 PM | #11 | ||
Rep 104
11-11-2018, 04:15 PM | #12 |
Rep 560
Not sure but on my old E90 330D you could reset by turning the car on and pressing the gas pedal down to the floor for 30 or 60 seconds ( not starting the engine just turning the ignition on )
Afterwards the car felt different, the gearbox lag would disappear and car would change gear different. |
11-11-2018, 06:49 PM | #13 | |
Eh? Team member
514
Rep 1,190
Drives: F31 335i
11-11-2018, 06:51 PM | #15 | |
Eh? Team member
514
Rep 1,190
Drives: F31 335i
11-11-2018, 07:02 PM | #16 |
Eh? Team member
514
Rep 1,190
Drives: F31 335i
Well, I meant how can you be sure you weren't imagining the improvements? When we expect things to be better they often are. It's human nature and it's called the placebo effect. Tablets with nothing in them except sugar make people feel better if they're told they are painkillers.
I've suffered from the same problem in the past with cars - such as believing that posh diesel in my old 330d made the engine less clattery (it didn't), that 98 petrol in my 335i noticeably improves mpg (it doesn't), that greasing the steering column or fiddling with the tyre pressures in my Z4 improved the steering twitchiness (it didn't). It took time for me to realise the truth. |
11-12-2018, 04:35 AM | #18 |
Rep 104
Seems to be that the Carly app doesn't reset the transmission in the way of it needing relearning using a certain sequence of driving as I don't have the time or skill to perform that procedure
Matt. |
11-12-2018, 04:43 AM | #19 | |||
Rep 15,858
The ZF 8-speed uses the ASIS platform. Quote:
For example, accelerator influenced adaptation. Quote:
I'm not getting what the 'reset' is actually doing, I suspect it's the old 'chestnut', around throttle adaptation defaults. It's certainly not gearbox adaptation values, we don't want to be messing with those, without valid reason. |
11-12-2018, 04:55 AM | #20 | |
Rep 709
The gearbox is still smoother now with at least 3,000 miles on it since it was reset. |
11-12-2018, 05:40 AM | #21 | |
Rep 560
I can honestly say it was different. My biggest issue with my E90 was the crap gear change. It was my first automatic and wasn't sold, in fact I was gutted that a VW with 200K miles on the clock was smoother than my BMW at the time I had the gear box oil changed and new gasket set fitted during the process for £500 by a BMW independent garage. It was that bad for me and my OCD I can honestly say that doing this changed the gearbox, it would go back to its old ways fairly quickly, like few days/weeks In the end the crappy gearbox and brakes forced me to sell the car. The F30 8 speed gearbox is totally different and what the E90 should have been for me |
11-12-2018, 06:02 AM | #22 | |
Rep 15,858
As you say that soon changes again, hence why some users perform the function (if it works for them) quite regularly. |
