05-27-2021, 08:09 AM | #1 |
Rep 99
BM3 datalog cyl 6 ignition timing = 0 + knock detected = 72
Hello all
2016 340i xdrive, stage 2.0 93+ OTS map. VRSF catless dp, cts intake, snow methanol injection. 94 octane fuel from Petro Canada. Logging last night produced some scary results. Power was there, 2 runs were done both with and without methanol. Without meth produced 480whp on virtual dyno, and with meth made 516whp. The logs are scary, it's showing a constant knock of 72 on all logs and cyl 6 timing is showing steady 0. Is this an error in logging or is something foul at play? Any insight appreciated, sorry if I left anything out. Logfile: https://www.bootmod3.net/log?id=60af...90c62c69a3f414 |
05-27-2021, 09:07 AM | #2 | |
Rep 532
is the car driving good ? , no shaking or something else
Bmw M240i Xdrive , Dorch Stage 1 , pure turbo 800 , Midpipe , Remus exhaust. Bootmod3 , 100+ E5
05-27-2021, 09:24 AM | #3 |
Rep 99
Oddly enough, yes the car seems to be driving perfectly fine. No shaking or any sounds that I could identify. The virtual dyno numbers were almost identical from before it was happening. I was suspecting injector or plug as well, this seems to be the easiest place to start.
05-27-2021, 11:23 AM | #4 |
Rep 99
Update: It seems there was an error with the logging, the values shown belong to the category below it.
I did another run today, I still see 2 knock events in the low range. https://www.bootmod3.net/log?id=60af...90c62c69a3f634 Is this ok? |
05-27-2021, 12:06 PM | #5 | |
Rep 532
is this log with the methanol or without
05-27-2021, 12:49 PM | #6 |
Rep 99
05-27-2021, 01:37 PM | #7 |
Rep 532
mmm, with the methanol your timing should be better... i,m not very familiar with WMI and settings and if you can adjust, but i think WMI should improve timing
05-27-2021, 04:55 PM | #8 |
Rep 99
I switched back to a less demanding Stage 2 tune and it seems to have done the trick, this log has much better timing - https://www.bootmod3.net/log?id=60b0...0b4342ae6f9482
05-28-2021, 01:12 AM | #9 | |
Rep 532
1slowb5840.00 |
