06-19-2023, 11:47 PM | #1 |
Rep 86
Dyno issues
What’s everyone’s work around to getting your RWD car to cooperate on the dyno?
Today I had my 2018 340i rwd on a Dyno Jet. We did a baseline run 2 months ago before I installed my upgraded turbo and it did fine in Roller Mode. No issues. Today, I put the car in roller mode except it would cut at 4200 rpm every time. We tried having the hood open, closed, Sport +, DSC Off, roller mode. I even took it off the dyno to drive it around to clear out the ABS/brake fault and it was fine. No codes or errors. Back on the dyno and the same thing. Any ideas? |
06-20-2023, 01:48 AM | #2 | |
Novice
303
Rep 695
For the future you should ask the dyno operator to set the dyno in AWD mode if its a dyno jet. At that point I think the hubs need to be locked? Or you need a tow hook. That should completely eliminate any problems and should run at your tune's power level |
06-20-2023, 08:42 AM | #3 |
Rep 86
I was reviewing my baseline GoPro videos which were filmed from inside the car and saw that the speedometer was showing 0mph. If I remember correctly, yesterday it was showing a speed. I’m thinking that the car wouldn’t go into dyno mode? It still doesn’t make any sense to me based off everything that we tried. Under partial throttle the car had no issues going to 6000 rpm. Once it was under load it would cut at 4200. On the street, no issues.
