04-14-2020, 10:02 PM | #23 | |
Rep 16,079
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 It's much easier to handle and fit into tight spaces than a drill, and at 7.2 volts has a lot more torque than cheap 3.6 volt power drivers. |
07-02-2020, 09:15 PM | #24 |
Rep 49
Current CPO coverage
Current CPO has more coverage. Found on different post.
https://f30.bimmerpost.com/forums/sh....php?t=1466905 See post #2 |
09-24-2020, 11:20 AM | #25 |
Rep 11
They need to replace that clip with a saddle block style clamp design. Here is a sketch I made up to show the concept:
https://photos.app.goo.gl/U4CQUGCkMNpaR2kF6 My local dealer told me they would replace it free under the Platinum Maintenance program the car was covered under that was purchased when the car was new. I have an appointment to let them fix it but in the meantime I have zip tied it up out of the way so it doesn't rub. It might be about as good as using the poorly designed clip. I will probably go back in and put in zip tie around the new clip and lines in case it breaks again or to help prevent it from breaking again. Here is a link showing before and after pictures and a video of how I did it after it was done. On mine only the right side of the clip was broken and I took the metal clip that is further back by the suspension off and pulled some of the slack out of the line and reattached it about an inch or so further up the line and then zip tied it around the back side of the heat shield bolt. https://photos.app.goo.gl/ja2cGzNfFuSPT77g9 Last edited by cgraner; 09-25-2020 at 08:50 PM.. |
01-03-2021, 05:15 PM | #26 | |
Rep 13
01-25-2021, 07:06 PM | #28 | |
M340i
392
Rep 967
Drives: BMW M340i
01-25-2021, 07:27 PM | #29 | ||
Rep 7,602
02-01-2021, 07:27 AM | #30 | |
M340i
392
Rep 967
Drives: BMW M340i
The parking brake cable clip should be in a sticky somewhere for common issues like all the oil leaks N55's get as they age. The noise created by the loose cables were driving me crazy. I kept thinking it was coming from the rear speakers. Nearly removed the entire interior including the seats to check all the speakers. |
02-13-2021, 11:50 PM | #31 | |
Rep 2
Did you have to remove any covers? How's repair holding up? My dealer wants me to pay $700 for my 328D. Says plastic and rubber parts are not covered by warranty. Im hoping I can take to my independent mechanic shop, user their lift and zip tie it myself. |
02-13-2021, 11:52 PM | #32 | |
Rep 2
02-16-2021, 03:52 PM | #33 | |
Rep 7,602
1. Rubber/plastic piece in question was completely falling apart. I showed the SA that just by touching it, it was disintegrating. He agreed and the invoice said "part was defective", so covered under warranty. 2. Sticky door lock on passenger side - another common issue where when you pull the door handle, the lock does not open. It just immediately pops back down. They did various tests and confirmed it was an issue and replaced the whole mechanism. 3. Exhaust flap rattle on cold start - they did a software update and surprisingly this actually fixed it. My warranty claim for the cable clip and some other work was on a separate visit. For #1 you should be able to just go in and show them the problem. As long as it looks like the part is failing and not because you used some chemical on it or otherwise caused it, you should be fine, buy YMMV with different dealer/SA. |
02-16-2021, 04:34 PM | #34 |
Rep 18
I got a 435i and ran into this issue, they zip tied it while I waited and said they'd replace the clip if it somehow drooped again (which I doubt it will)
Seems like the zip tie is better that OE tbh, easy to swap and the clip apparently breaks a lot so... |
04-17-2021, 10:39 PM | #35 |
Rep 13
Yall when I found out the clip was the problem after making my own forum, I bought the part. Got under there and saw all the work that needed to be done to get to it. So I zip tied it with a bunch of them to each other just in case it could get loose, and tried putting it as far back away from heat so they wouldn't melt and also cut the ends to make em not stick out (have to use big ones). Theres a spot to wrap them in a but back. 1k+ miles later still no noise and they're still there looking clean. Way better than doing all that work let alone paying a shop.
08-13-2021, 08:16 AM | #36 |
Rep 1,801
Im waiting on the clip to arrive but I'm glad I found this thread as the rattle has annoyed the hell out of me. I took off the rear bumper, took out the boot lining, took out the ceiling lining, took out the mid console with armrest. It was only when I got to the mid console with arm rest that I could feel the vibration on a part that linked to the hand brake. I then followed this back and it seems I'm going to have to do get under the car again.
such an annoying noise
Europe's fastest (stock block) F31 340i RWD | MPPSK | XHP 3 | Pure800 | Port Meth | Dorch 2 HPFP | MG Flasher
08-13-2021, 11:23 AM | #37 |
I can haz cheezburger?
6799
Rep 3,677
Drives: 14 Sahara/08 335xi/22 Maverick
Wanted to share my updated zip tie repair from another thread. My 428 developed this issue spring 2020. Around late September 2020 I attempted the zip tie fix and took me maybe 20 minutes to jack up the rear of the car, crawl under and double zip tie both lines. After maybe 80k miles (I drive too much), zip ties are holding up well.
celsdogg323.00 |
08-15-2021, 04:39 AM | #38 |
Rep 1,801
I couldn't really see where to zip tie the lines so I just clipped them together. Proper tricky to get to with the car just on axle stands but a quick test drive and it's not noisy now. I'll probably do the proper fix in a week or so
05-22-2022, 11:45 AM | #40 |
Rep 706
Does anyone know if my clip is broken or i just need to tuck it in? Does anyone has a picture on how the clip looks like?
When the mechanic showed me the clip, it seems like both the inner clips are shorter than the outer clip (i see it from rear near exhaust facing front), that means the the parking brake clip needs to be replaced? It’s hard to take picture but this is as clear as i can get. I took my picture from rear of the car. I also found this picture on youtube, but I don’t know how this part is installed. Can you please let me know which way is facing front of the car and which way is facing rear of the car? Is it the blue or green as marked by me? Last edited by gameson; 05-22-2022 at 12:27 PM.. |
05-22-2022, 11:32 PM | #43 |
Rep 1,386
Seemed to be a thing up until the 2016 model year. I'm not saying it's super common, but there are a few on here that have experienced the issue. The leak is up on top somewhere on my 2015 diesel. The dealer wants about 1/3 of the car's value to fix mine by replacing the whole tank. I put a squawk in with the NHTSA for all the good it will do. I'm going to see an Indy guy about a more realistic fix.
435 coupe |
