05-17-2018, 11:39 AM | #1 |
Rep 184
Drives: 328i N26
Intercooloer needed for bootmod3 stage 2?
So I'm getting of my JB4 Stage 2 (its for sale on the forum if anyone wants it) and looking to upgrade to the Bootmod3 but im not sure if i should go with stage 1 or stage 2. My main thing is it says stage 2 requires an intercooler and catless dp. I already have the catless dp from ER, but im wondering if the intercooler is really that necessary?
05-17-2018, 12:46 PM | #2 | |
Rep 3,680
Cnoprea50.00 |
05-17-2018, 03:37 PM | #4 |
Luke Wright
166
Rep 252
You can but depending on where you live you'll heat soak like crazy. Even with my JB1 I was heat soaking. If you were fine on JB4 without it then you'll be fine without it on BM3 but I would recommend a FMIC
05-17-2018, 04:23 PM | #5 |
Rep 891
I'm only using a JB+ and on hot days I can absolutely feel the car pull timing to compensate for the intake temps. I would go as far to say that if you live in a hot climate a FMIC is a practical/viable way to make more power even on an otherwise bone stock car. They are tiny and it is very easy to ask for more performance than they can provide.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i |
05-18-2018, 09:53 AM | #7 |
Rep 2,382
In most places, yes, it's required. If you live in Canada and it's cold as hell every day, then sure you can go without it. Really the key part is the DP and FMIC is to keep your IATs managed. You can run stage 2, but if it gets too hot, you're gonna lose power.
2013 F30 328i: MHI Big Turbo, GFB DV+, Mishimoto CAI, ER TIC/CP/Catless DP, AWE Touring Quad Exhaust w/ Resonated Midpipe, NGK LI Plugs, BM3 with PTF Stage 2 91 AGG Tune, Fuel-it Stage 2 LPFP, Solowerks S1 Coilovers, and DEPO/M-Sport Retrofit |
05-23-2018, 05:57 PM | #9 |
Rep 191,518
Yes an intercooler is needed for stage 2
06-06-2019, 04:22 AM | #10 |
Rep 122
I live in Canada where temperatures are pretty low for about 9 months of the year (6 months freezing) and I'm in the same boat as the OP, I have a jb4 with a catless dp, axleback exhaust, and an intake but no fmic. can I get away without the intercooler? I drive the car about 3 days a week for short distances. I heard only stage 2 maps will clear cel codes that's why I wanna go with a stage 2.
What's the worst that could happen on warm days if the stock intercooler wasnt doing it's job efficiently? will anything bad happen to the engine / Turbo? or will the ECU detect overheating and pull timing therefore reduce power to protect them? and if power gets reduced will the car be like in limp mode or will it feel more like in comfort when it's actually in sport?
Dinan Stage2 | Fabspeed High Flow DP | Dinan Carbn Air Intake | Remus Exhaust | H&R Sport Springs | 19" Savini Wheels | Continental ExtremeContact Sport Plus | Rear Diffusr | M4 Carbn Mirror Caps | Smoked Sequential Mirror Signls | Lip Spoiler | **PREVIOUS VEHICLE: 2013 BMW F30**
**INSTAGRAM: aphotic_f32 ** |
06-06-2019, 06:19 AM | #12 |
Rep 5,413
You need the intercooler upgrade. Luckily you can install BM3 Stage1 immediately and just flash Stage2 when you're ready
06-06-2019, 09:20 AM | #13 | |
Rep 122
also like i previously asked, is it true that ECU will reduce power if stock intercooler wasn't being efficient enough & running hot? If yes, then I see no risk, only downside is reduced power for those odd times. I only drive the car for about 3 days a week only when it's not raining and in winter the car is stored and we have cold weather for the biggest time of the year so I would put my money in to other mods. |
06-06-2019, 10:15 AM | #14 | |
Rep 415
I’m assuming there is a risk of running hot on the components and the DME always have to compensate for that. I don’t have technical info to back this but there is likely a risk of premature wear if not cooled properly. |
ty66671.50 |
06-06-2019, 10:23 AM | #15 | |
Rep 5,413
I'd suggest posting your question to see what the experts say. Also once you purchase BM3 you can gain access to their FaceBook page that has a lot of helpful information and helpful users. I personally would run with Stage1, if you find that it definitely clears CELs, rather than make your car's safety systems work that hard. |
06-06-2019, 10:59 AM | #16 | |
Rep 60
06-11-2019, 09:14 PM | #17 | |
Rep 191,518
12-02-2021, 11:01 PM | #18 | |
Rep 1
12-02-2021, 11:14 PM | #19 | |
Rep 709
do you want to save $300 and pay $1000s in repair fee? you will soon regret you blow up your engine just to save $300 on fmic you need to think about risk and reward. if you wanna go fast, you must budget everything (fmic, downpipe, charge pipe at minimum. to be safe, change boost pipe, and inlet pipe as well), if you can not afford bm3, downpipe, charge pipe, and fmic (this amount to low $1000s total), then just don't do it, save, and do it when you have the money |
05-31-2023, 02:07 PM | #21 | |
Rep 191,518
Please note that running hot during street driving doesn't immediately equate to diminished performance. However, consistently running hot can lead to reduced ignition timing, which in turn results in less power. Monitor IAT, If you notice a significant increase, cross-check your ignition timing to see if your DME is reducing it. If this is the case, upgrade your intercooler. Of course, this is a simplified explanation of the issue. lots of other factors are involved. But in my opinion, that's a great start.
06-01-2023, 05:39 PM | #22 | |
Rep 9
