BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > CANADA > 2014 F30 335xi M PPK Estoril Blue
Studio RSR
      10-24-2013, 12:39 PM   #1
12eb3L
Exclamation 2014 F30 335xi M PPK Estoril Blue
      10-24-2013, 12:59 PM   #2
bobblehead
bobblehead's Avatar
Drives: warp speed
based on bmw website -
- Xdrive is 40/60 but can move to 100% to either axle.
- tq vectoring http://reviews.cnet.com/2300-10863_7-10007878-5.html
now sends more torque to the rear wheels during cornering and has adopted a much-faster-acting computer system. During cornering, it can move to a 20/80-percent split to counter the understeer. Also aiding the ability to rotate fluidly is a torque-vectoring system that applies the brake to the inside rear wheel while feeding a bit more power to the rear end—and therefore to the unbraked outside wheel—to compensate for the drag
- winter tires are always recommended, for reason of better snow traction but for proper braking as well.
- suspension setting is different from RWD.
- A.S.S can be turned off at the last setting and will not be defaulted back to ON unless you press the button again
- Weight distribution : RWD - 50/50 ; Xdrive - 51/49
- Mods - if you have the $, your options are limitless.
      10-24-2013, 01:27 PM   #3
bobblehead
bobblehead's Avatar
Drives: warp speed
xdrive typically will have a slightly higher spring setup (for snow clearance), thus having a bit more wheel well gap than RWD. But most xdrive owners can opt to change the springs to like HR, Eibach, etc. to lower the car, simply for look (bit of aggressive stance)
      10-24-2013, 01:43 PM   #4
bobblehead
bobblehead's Avatar
Drives: warp speed
You should also consider ordering the car with M Perforance Pkg (ZHD) $1500 as it has M adaptive sports suspension which will give you the damper control for better road handling situation.
http://www.f30post.com/forums/showthread.php?t=844159
See post # 6 for the PDF attachment ordering guide
      10-24-2013, 04:25 PM   #5
jtuds
Drives: 335rwd Dinan S2
Originally Posted by reyoasian View Post
Reverse, it automatically shifts to Parking when you hit the gas pedal?? (was trying to back in without sensor or rear cam)
You have to open the door to reverse a car that doesn't have a parking sensor or camera?
You do realize there are rear view mirrors and a back window, right?
      10-24-2013, 08:06 PM   #6
bobblehead
bobblehead's Avatar
Drives: warp speed
I don't believe coilovers are available for the xdrive ???
      10-24-2013, 08:54 PM   #7
meeru
Drives: F30 328xi Sport Line
I knw this is not the right threaddd! But plz someone help me with getting a performance exhaust for my f30 328xi.. Being quoted around $1300 here in gta
      10-24-2013, 09:15 PM   #8
Dan_335i
Drives: 2014 335i EBII MSport
You can always buy one for usa and install at a local auto shop that works on german cars
      10-25-2013, 01:23 PM   #9
TPYD
TPYD's Avatar
Drives: 2012 F30 335i
+1 Since I just changed my sport suspension to Bilstein PSS. I believe no AWD compatible coils are in the market yet for F30's.
      10-25-2013, 02:39 PM   #10
meeru
I mean i do live close to buffalo but im clueless when it comes to ordering and installing parts. Because I was hoping someone who hAs done something like this could guide me! Much appreciated thanks!
      10-25-2013, 04:16 PM   #11
bobblehead
bobblehead's Avatar
Drives: warp speed
Before you order anything, go to the Woodbridge meet (Costco / Weston & 7) next Sunday (Nov 3) to take a look who has done the change and I am sure there are lot more owners who can answer your questions in better details.
      10-25-2013, 11:31 PM   #12
meeru
Thank u sir..
