07-16-2017, 04:55 PM | #45 |
Rep 1,479
Drives: 2020 M340Xi (G20)
Ooshnoo,
I am 5' 10- 11" and have a 2014 F30 and coded the following in the SM2 module: 3000 SM_Global_6 >EINAUSSTEIGSHILFE from nicht_aktiv to Modus_FA_SLV 3012 EAH > EAH_VERFAHRWEG_SLV_PHYS from 00, 3C to 00, 37 3012 EAH >EAH_SCHUTZFREI_RAUM_HINTEN_SLV_PHYS from 00,64 to 00, 37 I did this coding almost 2 years ago and it has been working like a champ:if you need to adjust, the values are millimeters, but stated in hex Hope that helps
Al
2020 M340Xi| ZDA| ZDY| ZPP| ZPX| 1CR| 1PL| 688| 6NW| 2VFH| Retired: 2014 328i BMW CCA |
07-16-2017, 06:54 PM | #46 | |
Rep 2,180
What about your FEM_BODY coding?
FEM_BODY Module: 30C0 EINSTIEGSH_LN_AKTIV set to: aktiv 30C0 EINSTIEGSH_NG_AKTIV set to: aktiv 30C0 PRIO_ACHSEN werte = 02 Quote:
07-16-2017, 08:14 PM | #47 |
Rep 1,686
Drives: 2014 428i and 2018 X5
Yep. I coded the last one right after i posted here, and still it doesn't fully work. The first 2 were already set to aktiv.
08-31-2017, 11:57 AM | #52 |
Rep 158
Curious as to why coding for these modules is needed if no electric steering column? When I got that section it's titled Electric Steering Wheel.
08-31-2017, 08:00 PM | #53 |
Rep 158
I'm striking out on this one. I'm 6'3" and wife is 5'0" so it seems like with that variance some of the settings above would not work.
Initially when I used: In the SM2 (6d) module: 3000 SM_GLOBAL -> EINAUSSTIEGSHILFE = Modus_FA_SLV 3012 -> EAH_VERFAHRWEG_SLV_PHYS = Werte=00, 28 3012 -> EAH_SCHUTZFREIRAUM_HINTEN_SLV_PHYS = Werte=00, 3C Her seat was working correctly but when I opened the door the seat was still slid way forward. I changed: 3012 -> EAH_VERFAHRWEG_SLV_PHYS = Werte=00, 28 and raised the last value to 64 and then 90 and that made my seat go back to near the correct position but then on hers when she opens the door there is no easy entry, it is just what I would call easy exit where it slides back upon exit. Gave up for now and put all settings back to standard and came here for some advice on what values might work? Might have to break down and hire a coding service on this one. |
09-01-2017, 06:32 AM | #54 |
Rep 765
the code doesn't control how far up it slides up. It slides back when u open the door according to settings n when u close n start engine it slides up to last position (u must have "return to last position" selected in idrive)
Now can someone help me?? Why I only have one sm2 module?? Does everyone have 2 and if so do u have memory seats on passenger side too?? I coded drivers side fine but can't find other sm2 module. Smfh Thank you!! Last edited by Jhnblckwood; 09-01-2017 at 06:41 AM.. |
09-01-2017, 06:38 AM | #55 | |
Rep 765
Sorry I might have misunderstood. Try changing 3012 -> EAH_SCHUTZFREIRAUM_HINTEN_SLV_PHYS = Werte=00, 3C To 00,00 But be careful when ur seat goes back it doesn't crush someone behind you. |
01-06-2018, 10:44 PM | #56 |
Rep 4
I just coded the 3 lines below in my new F30 (340i ‘18) and it worked like a charm. I must say though, the ECU in this models is now called CFAS.
3000 SM_GLOBAL -> EINAUSSTIEGSHILFE = Modus_FA_SLV 3012 -> EAH_VERFAHRWEG_SLV_PHYS = Werte=00, 28 3012 -> EAH_SCHUTZFREIRAUM_HINTEN_SLV_PHYS = Werte=00, 3C |
02-07-2018, 06:48 AM | #57 |
Rep 2,127
Just coded this on my 440i and it works perfectly. I just used the cheat codes in esys to do it, but I think the settings are the same as MrTowers above.
04-16-2018, 07:01 PM | #58 |
Rep 692
I have a 2016 f30. Coded the seat for easy entry and adjusted the 2 positional values as explained in this thread. NOTHING works for me.
Is the 2016 LCI not supported? Edit: I'll take that back. After changing the max value to 00,00 it does appear to work. I had originally set it to 20mm but apparently that was not enough. I do sit pretty far back and I am 6ft2. |
04-17-2018, 08:05 PM | #59 | |
Rep 692
I am doing nothing different. Not even moving the seat manually. It's always set to my preferred memory 2. Just the same way as when it DID work a couple of times. Any ideas?
Bimmercode best coding options (Basic and Advanced):
https://g20.bimmerpost.com/forums/sh...5#post29807925 |
05-12-2018, 04:51 PM | #60 | |
Rep 125
I am trying to code for this using bimmercode.... In expert mode, I can find the items, but to put in the values you guys mention(werte 00, 28), in bimmercode code it says byte 0, OxOO......do I put in Ox28?.... |
DThr33635.50 |
05-16-2018, 08:37 PM | #61 | ||
Rep 692
05-20-2018, 01:13 PM | #63 |
Rep 125
05-20-2018, 05:31 PM | #64 |
Rep 692
Yes. But no VO coding.
06-02-2018, 05:47 AM | #66 | |
Rep 1,909
Byte 0 0x00 Byte 1 0x3c Do you just change the Byte 0 line?
Happy Motoring
Evdok |
