11-19-2018, 08:19 AM | #1 |
Rep 1,447
Battery discharge after parking for 2 days?
First time this happen to me. I park my car in my condo underground parking( 7 degree Celsius) for 2 days. When i go to me car try to pull the trunk handle to open lid with key in my pocket, it won't open. I press the button on my key, it opens. When I turn on ignition, idrive shows me high battery discharge!? But i can turn on engine.
My car is a bit over 3 yrs old. Back in September, dealership did full inspection as a 3 yr service requirement. It shows battery at 70% charge. But they didn't replace it. On phone, battery needs replacement when it holds less than 80% charge, what about car? Is battery covered under 4 yr bmw factory warranty here in Canada ?? |
11-20-2018, 12:13 PM | #2 |
Rep 2,524
Pretty sure it's not covered.
I don't know what your driving habits are, but short drives and heavy electricals do impact these cars. Have you tried a battery charger? |
11-20-2018, 12:14 PM | #3 |
Rep 1,447
11-20-2018, 11:26 PM | #4 |
Rep 1
I had the same issue the other day, where i did not drive my car for 4 days. After stoping at the store, i went back in the car and the battery discharge warning was gone. I have not return.
11-21-2018, 09:19 AM | #5 |
Rep 400
Happened to me once, I was washing my car and had the music on full blast for like 2 hours. Luckily I was able to start it, after getting the same battery discharge message. Took the car for a quick spin and everything was back to normal. I have also heard cases of battery discharge when its extremely cold -20 to -30.
11-21-2018, 09:26 PM | #6 |
Rep 1,055
Drives: 2016 340i M Sport 6MT+RWD
This has already happened to me a few times last year when it got cold - my car was only 1.5 years old... it can mean a few things.
- You're not driving far distances for the battery to charge sufficiently without discharging while parked. BMW vehicles don't recharge the battery like traditional vehicles due to emissions. The ECU will engage the alternator while coasting, braking, and sometimes highway driving - in effort to save fuel - Something is draining your battery while the car is parked. Disable your location services or other ConnectedDrive features. Worst case you may have an electrical issue but I doubt it - With Cold temperatures, the car will see dropped voltage from the battery; hence you're seeing the message - especially combined with the first bullet point (your driving pattern) - Finally, it could mean it's already time to replace your battery which would definitely suck. It's a wear and tear item so I don't think it's covered under the warranty It's recommended to trickle charger your vehicle in winter every month or so - this will help the battery keep topped up which is good for AGM batteries. I plan to do that this year since I got lazy last year - although I'll be driving my car more often now so I don't know if I'll still see that message.
2016 Estoril Blue II 340i M Sport | ///MPPSK | 6MT | RWD | Fully Loaded
BM3 Stage 2+ 93 | B58TU HPFP | VRSF v2 Catted Downpipe | 550i Clutch |
pokerface429.50 |
11-21-2018, 09:39 PM | #7 | |
Rep 1,447
11-22-2018, 02:18 PM | #8 |
Rep 375
Drives: 2020 M2C DCT
My X2 was parked for more than two weeks and there was no problem at all starting it, nor was there a warning message about the battery.
11-26-2018, 08:54 AM | #9 |
Rep 333
Yeah I had that issue with the 2011 E90 and the 2014 F31...short city trips all the time didn't recharge the battery enough, so once or twice a winter I would put the trickle charger on for a night to top it off...
2018 F80 M3 6MT (current)
2014 F31 328i Touring (sold) 2008 E92 M3 6MT (sold) 2011 E90 335xi (lease up) |
11-27-2018, 09:12 AM | #10 | |
Rep 1,055
I think I ended up accelerating this scenario on my F30 because I was using parking recording with my front + rear dash cams (hard wired) for a good year or so until I started driving it less. I set the dash cams to stop recording when the battery hit 12.1V while parked but even then, I noticed the dash cams would shut down sooner compared to when I first installed them. They used to record for 10+ hours before hitting the voltage cutoff then eventually they wouldn't even stay on for more than 1 hour so I stopped parking recording altogether last winter. I'm actually going to externally charge my battery soon and start parking recording again to see how much of a difference that made. Anyways - I went a bit off topic but PSA from me is don't do parking recording on BMWs unless you have a battery pack, otherwise you'll put a toll on your AGM battery
11-27-2018, 12:48 PM | #11 | ||
Rep 1,447
11-27-2018, 01:45 PM | #12 | |
Rep 1,055
Check out Cellink Neo or Blackvue B-124 - they're expensive but they're dedicate for this type of use.
