11-21-2018, 11:31 AM | #1 |
Rep 61
2014 F30 335i - Active Sound?
Does the 2014 F30 335i have Active Sound? What is the easiest way to figure this out?
I coded my car using Bimmercode a few days ago, and I swear my car is completely quiet now inside of the cabin. I had an MPE installed through dealership, do they code anything to make it louder inside the cabin? Prior to coding, it seemed louder from inside like there was Active Sound, but when I go into the app... there is no Active Sound module. I also noticed coding my car, some settings were wiped to default (such as stereo/audio settings), so I'm wondering if Active Sound was one of them, but I can't enable it again since it's not available. |
11-21-2018, 01:24 PM | #2 |
Rep 463
I believe ours do have AS, but hopefully someone can confirm.
However, the BimmerCode app “saves” the current settings prior to your coding for new settings. Ideally, you should be able to revert to the “default” or last coding change (by date) and settings your car had? Load that and then see if you have the options you require. |
11-23-2018, 12:19 AM | #3 |
Rep 61
If anyone has any solid knowledge on this, would be much appreciated. I've read on several places, multiple people say 2014 F30 335 does have Active Sound, however Bimmercode support told me it doesn't.
11-23-2018, 09:44 AM | #5 |
Rep 4,657
I am pretty sure, at least in 2014 onwards, that there is active sound on the 335.
