BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Coding cable and ESYS, psdzdata
      02-10-2015, 04:26 AM   #177
shawnsheridan
shawnsheridan's Avatar
Originally Posted by franzzz View Post
Hello shawn,
Flash all main ECU with Esys 3.26.1 and psdzdata 2.53.5 . (no ACSM and TV modul)
no errors
all ecu and car work correctly and fine
With inpa after a error scan i find a "unk error" 08x4113 on CAS
Ok. Maybe you are not using right CAS.prg for your CAS Module.
      02-10-2015, 04:35 AM   #178
franzzz
franzzz's Avatar
Italy
142
Drives: BMW M4
no is the correct cas4.prg and cas4_2.prg
before the update no error
i think due to a missed parts or compatibility with my retorofitted cruise control or TV modul
i try to put a sreenshot soon
BMW F82 M4 Black MHD CS Map - GTS DKG - Navi -Performance Brake RSL1 Pads - USB - DivX-DVD - Bluetooth - VoiceControl - Connect - Apps - Online - H&K - TrafficInfo - SpLimInfo - WhiteMerino- PDC - Cam - Adaptive Led - Antitheft - CP Steering- Performance ST - Adaptive CP Setup - GarageDoorOpen - Pipercross - Stock Exhaust - Mdrivers Pack - 437M Wheels
      02-10-2015, 04:38 AM   #179
shawnsheridan
ops Are you UP on 4.24 am !!!!
I sleep 3 hours per night, whether I need it or not...
      02-10-2015, 07:38 AM   #180
franzzz
franzzz's Avatar
Italy
142
Drives: BMW M4
OK @shawnsheridan this is generic CAS error
      02-10-2015, 07:41 AM   #181
franzzz
franzzz's Avatar
Italy
142
Drives: BMW M4
and the problem is generated by FEM_BODY
I think I have activated a feature not present in my car
I do not know which one.
The error talk about a missed signal from internal antenna.
Wi fi ?
TPMS sensor ?
      02-10-2015, 07:56 AM   #182
shawnsheridan
Sorry, but I have no idea.
      02-10-2015, 08:11 AM   #183
franzzz
franzzz's Avatar
Italy
142
Drives: BMW M4
it's possible to compare 2 CAFD files ?
I have restored the old CAFD from my old 2.52.5 configuration. No errors.
      02-10-2015, 08:13 AM   #184
smithf80
smithf80's Avatar
Drives: G80 M3 6MT
2022 G20 330i  [9.00]
2018 F80 M3  [9.75]
If you clear all the errors does this come back?
Just try that before going crazy. Do you have anything retrofitted?
      02-10-2015, 08:16 AM   #185
shawnsheridan
Yes. Use TokenMaster's NCD / CAFD Tool.
      02-10-2015, 09:17 AM   #186
franzzz
franzzz's Avatar
Italy
142
Drives: BMW M4
TNX !!!!!!!!!!!!!!!!!
Discovered the problem !!!!
After my update of 2.53.5 and coded all ECU, only FEM reported one error
The antenna is the number of interior antenna in order to detect the key
6C is the correct value for my F30 01/13
      02-10-2015, 09:19 AM   #187
shawnsheridan
Good catch.
      02-10-2015, 09:22 AM   #188
franzzz
franzzz's Avatar
Italy
142
Drives: BMW M4
Good catch.
Tnx !!!
Shawn any advice for me about the update of NBT from 2.52.5 to 2.53.5 and the issue "no media no usb no dvd" ?
      02-10-2015, 09:27 AM   #189
shawnsheridan
Tnx !!!
Not really. You lost all media functions after 53.5 flash? Did you use factory original FA during Flash?
      02-10-2015, 09:30 AM   #190
phattbam
Drives: '17 Protonic Blue i3 REx
So after non transmission related coding. My car remained in "M" manual mode today. I have a "15 335i msport. Left it in normal "D" drive mode. Clicked the left downshift paddle and went along my way. As it picked up speed it never up shifted. I had to manually shift it. Any one else experience this odd behavior?
      02-10-2015, 09:34 AM   #191
franzzz
franzzz's Avatar
Italy
142
Drives: BMW M4
In order to complete the update off ALL ECU to 2.53.5 i need only the last two :
ACSM
HU_NBT
I have read a big issue to ACSM (problem when update with ESYS) and NBT issue after a flash (media units does not work after update)
it's true ?
      02-10-2015, 09:36 AM   #192
franzzz
franzzz's Avatar
Italy
142
Drives: BMW M4
if you keep a cruise speed the gear came back to D after 10-30 sec....
during accelerations or decelerations the gear still im Mx
      02-10-2015, 12:02 PM   #193
phattbam
I'll give that a try this evening. but as i continued to accelerate normally. it just held onto the gear high into the revs.
      02-12-2015, 09:22 AM   #194
nstratica@gmail.com
Drives: F25 2oD XDrive
E-Sys and PSdZData, and ENET Interface Cable is for Fxx chassis only.
NCS Expert / EDIABAS and SP-Daten, and DCAN Interface Cable is for Exx only.
Hello.
I'm new in action. Sorry ...
I want to extract the FSC from my F25 24.06.2013 but my version of SW ID Reader (1B) V1 expected an error @ EDIABAS in russian version.
Please can you help me ?
Thanks in advance.
NS
      02-12-2015, 09:27 AM   #195
shawnsheridan
Originally Posted by nstratica@gmail.com View Post
Hello.
Thanks in advance.
NS
For F25, just use E-Sys to extract 1B.
      02-12-2015, 10:57 AM   #196
nstratica@gmail.com
Hello,
Sorry again. I'm a beginner.
I'm afraid but I don't understand how I had to read 1B.
I'm using E-SYS 3.22.5 and PZData 48.2 and when in expert mode (coding) try to read any CAFD_, E-Sys tel me : File for "CAF_xx" not found [C012].
I'm big stupid or I don't have correct programs.
Thanks in advance
nstratica@gmail.com
NS
PS You moved really quick.
10x
      02-12-2015, 11:02 AM   #197
shawnsheridan
Hello,
Thanks in advance
nstratica@gmail.com
NS
10x
You need to update your E-Sys and PSdZData.
PM sent.
      02-12-2015, 12:56 PM   #198
nstratica@gmail.com
Hello,
Many thanks.
It's a shame not recognize when things do not know, when you
want to know and do not know as a privilege. 10x for privilege.
Down all, Read all, Install all and hope to solve my problem.
NS
