02-12-2015, 11:15 AM | #156 |
Rep 3,089
Thanks Martin. This is just a placeholder until I get a "REAL" exhaust!
02-12-2015, 12:30 PM | #157 |
Rep 3,089
The right exhaust tip was was just a little over 1/8" lower than the left one so of course I had to fix it. Even though 1/8" does not sound like much, the difference in height between the tips was really apparent to me. Luckily the left/right alignment was spot on since adjusting the height is easy. I just used some 75lb (really really strong) tie wraps on the muffler hangers. It took me about 5 mins. I am much happier now! The OCD mind can rest until the next mod comes along that requires me to obsess over.
Before: After
02-12-2015, 02:38 PM | #159 | |
Rep 5,316
Drives: G80 M3 6MT
Scott, Partner
Insight Automotive Consulting Click HERE for all discounted BMW New Car Pricing Click HERE for all BMW In Stock Inventory Specials Call/Text: 516-416-5481 Email: scott@insightautoconsulting.com |
02-12-2015, 02:39 PM | #160 |
Rep 316
Drives: X1, i3 BEV
Considering spacers for my f36 as I just noticed the rears look pretty sunk in. Any chance you could take a picture of yours down the length of the car so I could get a feel for the 10/12 setup?
02-12-2015, 02:59 PM | #161 | |
Rep 3,089
Touche! I may have to out to the garage and doublecheck with my mm ruler so I can get more accurate meausrements!
02-12-2015, 03:17 PM | #162 | |
Rep 316
Drives: X1, i3 BEV
02-12-2015, 04:20 PM | #164 | |
Rep 3,089
Thank you. You cant go wrong with either car. They are both beautiful. Ask yourself if you can use the hatchback and the extra space of the 428i. I personally find the space very useful. I've already taken advantage of it by hauling a few things that would never fit in a trunk. BTW, I have visited your beautiful country (Mechelen, Antwerp) several times on business and have always enjoyed my stay.
02-12-2015, 04:29 PM | #165 |
Rep 3,089
If you look at the first pic I uploaded for you the wheels definitely looks pushed out more without any poke. To me thats a nice conservative look.
02-12-2015, 04:51 PM | #166 | |
Rep 5,316
Drives: G80 M3 6MT
Scott, Partner
02-12-2015, 05:05 PM | #167 |
Rep 340
02-12-2015, 05:23 PM | #168 | |
Rep 3,089
M4 fo sho!
02-12-2015, 06:32 PM | #170 |
Rep 3,089
GTR! I would love the drive that beast!
02-13-2015, 09:02 PM | #171 |
Rep 510
Finally check out your ride....hehe. Damn! Nice 428 GC bro! The area looks familiar to me hehe....dude get Vorsteiner rims. They will look badass on your GC
02-13-2015, 09:10 PM | #172 |
Rep 3,089
02-14-2015, 03:03 PM | #174 |
Rep 3,089
UPDATE: 14-02-15 - iND Painted Front Reflectors
Since I am newly single I didnt have much to do today (LOL) so I decided to install my iND painted front reflectors. The whole process took me about 1.5 hours mainly because I took my time. Here are some pointers that I hope helps others: Tools: Angled plastic trim removal tool Hair dryer 8mm socket Degreaser/cleaner Finger nails/raw skin Reflector removal: After opening the wheel well liner I proceeded to slowly heat the back edge of the reflector. Using my hair dryer on med I heat the area for about 5 mins, constantly moving the dryer. I started on the back edge because that was the only place that made sense and provided room for me to work. There is a plastic lip right at the back edge of the reflector which is why an angled trim removal or flat tool is handy. Once I noticed a little bit of give in the reflector by pushing on it from the outside I proceeded to use my trim removal tool to get under the reflector edge. So as not to put too much outward pressure on the bumper, I made sure I pressed from the outside against the trim removal tool while also pushing the reflector inward. Once I was able to get the tool under the reflector, I worked the tool downward using it to "cut" the adhesive. Again I provided pressure from the outside of the bumper following the tool downward. Once the back edge of the reflector was loose I worked on top edge. Using the hair dryer again, I heated up the front edge of the reflector for another 5 mins. This time, instead of working from the inside, I used my trim removal tool from the outside. Starting from the top edge, I used my hand to pull on the reflector from the inside. Once enough of a gap was created, I inserted the tool between the reflector and bumper for the outside. Like before, I slowly worked my way down, "cutting" away at the adhesive. After getting about halfway down I could use my hand from the inside to pull away the reflector from the bumper completely. With the reflector removed I spent a fair amount of time making sure I removed all the left over adhesive. I did this using my degreaser, finger nails, and fingers, rubbing the adhesive away. Once I was satisfied that all the adhesive was gone I thoroughly cleaned the area. 1.5 hours later the car looks much nicer! One thing I noticed is that the painted reflector does not "look" to sit as flush against the bumper as compared to the stock reflector. I think this is an optical illusion caused by the body color reflector making the seam between the reflector and bumper more obvious. Also the Alpine White makes the shadow cast by the reflector edge more obvious too. Angled flat edge tool: Loosening the front edge: Before and after:
02-14-2015, 05:10 PM | #176 |
Rep 5,316
Drives: G80 M3 6MT
Very nice, amazing how something so small can help the look so much! I'll have to put mine in as well once its not below freezing in NY lol!
Scott, Partner
