02-13-2020, 12:20 PM | #1 |
Rep 5
Battery Drained within 1 hour
I charged my battery up to 100% over night and on my way to work (drive time is 1 hour) the battery was depleted by the time I parked it at work.
I've recently replaced the alternator and the battery is only 6 months old. I also bought the full version of CARLY and it found a few items that I need to take a look at but not sure where to start Here's what CARLY found; INFO 134A02 Valvetronic servomotor: overload INFO 135302 Valvetronic Servomotor: components protection, shutdown system INFO 133B06 Valvetronic system: No adjustment possible INFO 135706 Valvetronic system: learned lower stop INFO 216104 MSA Monitoring: Start delay INFO 21A023 Engine: false start or engine starting without a driver influence Where do I get the info on all of these error codes so that they can be resolved and perhaps solve the battery drain. My assumption is that one or more of these has something to do with the battery drain. |
02-13-2020, 04:50 PM | #2 |
Rep 7,597
My logic is that, if your battery drained while driving, your alternator is not working... I dont think anything could drain a sufficient amount of power to drain your battery while driving if your alternator was working?
Also low voltage is known to cause a number of issues... so how do you know those were not a result of the battery drain (and not the cause)? |
02-14-2020, 01:36 PM | #3 |
Rep 5
unless the alternator is bad, which I had tested along with the battery while at one of the auto shops in town. i believe it was Auto Zone. there must be something other than that causing the issue.
NOTE: I tested using sport mode while driving and it seems to charge the battery enough so that I don't see the error when parking. So the extra revs must be charging it enough to not lose much power in the battery. These are the only issues that stay after the battery is at 100% from a charge over night at 10A. charging at 2A leaves me at 60-80% after one night of charging. |
02-14-2020, 03:25 PM | #4 |
Rep 440
Drives: 2013 335i xDrive
If Auto Zone tested the battery and it passed, and the alternator passed also, something is seriously draining your battery.
One way to tell if the battery is being drained is to pull the negative terminal off the battery with everything turned off and measure the amperage between the cable and the post. Some amperage is normal with the trunk open (the light is on) but it should not be much. If it reads more than a couple of amps with everything off then that's a problem.
I'm not completely useless, I can be used as a bad example.
02-25-2020, 03:20 PM | #5 |
Rep 5
turns out up by the post for the battery in the engine area, a wire melted / welded itself to the body. The part is not available anywhere in the USA. Have to get it from Germany which means it gets put on a boat and it arrives 2-3 months later. Only alternative is to overnight on a plane. It's still a 2 week wait for the part.
02-25-2020, 07:08 PM | #6 | |
Rep 761
MG F30 M-Sport 6mt FBO w/ MHD stage 2 plus (PWG), ST XA Coilovers, 19" VMR V804.
02-26-2020, 12:09 AM | #7 | |
Rep 7,597
As mentioned above you need to trace it as well and make sure nothing else was damaged. |
04-01-2020, 01:53 PM | #9 | ||
Rep 5
And it did exactly that.. grounded to the frame |
04-01-2020, 01:57 PM | #10 | |
Rep 5
I wasn't aware that there is a connection between the firewall and the engine that needed to be put back in place. So, this has been rectified and everything is working MUCH better - including MPG is up from 24 to almost 29mpg This is due to the lack of cars on the hwy now. But it's an improvement. |
