BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > 119508 Rail Pressure Sensor Plausibility: Pressure Too Low Before Engine Startup
      03-04-2020, 02:52 PM   #1
rickyf10
rickyf10's Avatar
Drives: F80 M3
i know it's the wrong forum, my motor is s63tu on f10 m5, but there are not many people active on m5post so i decide to ask for some advice here
So few days ago in the morning, i started my car but CEL poped up, "drivetrain malfunction" poped up on screen and engine died soon after rev tried to stablize around 800 during cold start. Then i scanned the code and got:
118011 Mixture control, Across bank mixture too Rich. (this one doesnt trigger CEL)
I flashed back to stock tune (was running bm3 stage 1), and tried to start again. The rev fluctuated around 800 again but car didnt die (along with kinda rough idle). After driving off, the car just ran fine.
So today I kept eye on rail pressure and notice that rail pressure was very low (around 100 psi) before i started it up, and after I started engine, it rise to 1800 psi (is it normally that high????), along with rough idle as last time.
note: all 8 injectors were replaced half a year ago due to leaky injector
anyone has idea on this problem?
      03-04-2020, 03:48 PM   #2
Munchi435i
Munchi435i's Avatar
Drives: 2014 Alpine White 435i M-sport
I've had a similar code when my HPFP was starting to fail to keep up with my tune. Even happened while idling for an hour, tried to drive off and the drivetrain message came up but was able to restart the car immediately after.
So check your HPFP of maybe the LPFP.
      03-04-2020, 03:51 PM   #3
n55david
n55david's Avatar
2017 m240i xDrive  [0.00]
2015 X3 x35i  [0.00]
2015 335i xdrive  [0.00]
well first thing, reset the adaptions. Make sure you dont have any weird leaks in the intake side of things or anything that could cause bad sensor values.. next id change the upstream 02 sesnors.
Thats what I would do. Im also wondering if you have a leak somewhere or a pump thats dying and rail pressure is dropping until it builds back up. Does it have trouble starting on the first try?
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD
2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots
IG: @n55david For pics and updates!
Youtube: @ n55david For videos or Racing etc
      03-04-2020, 07:45 PM   #4
rickyf10
rickyf10's Avatar
Drives: F80 M3
HPFP, yep, this is what I suspect too. Just not sure how to test HPFP too see if they are actually faulty.
      03-04-2020, 07:49 PM   #5
rickyf10
rickyf10's Avatar
Drives: F80 M3
Yep! I'll be clearing adaptations today to see if it helps. i dont see any leak in the engine bay tho. My mechanic suspects O2 sensors are the cause (since im running catless downpipe) and he's gonna put on O2 bypass today. I'll be updating this later
      03-04-2020, 07:55 PM   #6
Munchi435i
Munchi435i's Avatar
I'd say try the 02's first since that would be cheaper than HPFP. I'm not sure how to test the HPFP but systemically start from the least expensive points would be my suggestion.
      03-04-2020, 08:48 PM   #7
DreamerJoe
Drives: 2017 340i M.G. w red interior
if you have any tuning software like mhd or bm3 you can take logs. and I think you can pull up the info real time using a BT obd2 dongle and the torque app, just not sure if you can log and save the data
MG F30 M-Sport 6mt FBO w/ MHD stage 2 plus (PWG), ST XA Coilovers, 19" VMR V804.
      03-04-2020, 09:06 PM   #8
rickyf10
rickyf10's Avatar
Drives: F80 M3
i do have datalog recorded by bm3, it's a cold start up.
http://www.bootmod3.net/log?id=5e5dae3dd10b4369882e10bf
i have consulted bm3 support and they say afr seems way off but they can't tell which part is mechanically wrong
      03-04-2020, 09:22 PM   #9
Munchi435i
Munchi435i's Avatar
Need a proper log. You need to do the log in 3rd if 6MT or 4th if 8AT, start at about 2500 RPM, floor it (dont roll into it) and log until about 6500 rpm and stop the log. Get 2 or 3 logs like that. Also, make sure DSC is fully off and if auto transmission, make sure you are in manual shift mode not just sport shift.
      03-04-2020, 11:28 PM   #10
rickyf10
rickyf10's Avatar
Drives: F80 M3
DSC fully off????? I’m 7dct btw.
I’m now installing o2 bypass and reset mixture adaptation later to see how it will be going
      03-05-2020, 10:25 AM   #11
n55david
n55david's Avatar
2015 X3 x35i  [0.00]
do a full throttle log from 3rd gear to as high as you can go.
make sure traction control is off.
      03-05-2020, 10:50 AM   #12
DreamerJoe
put the car in sport +, then hold the DSC button for 5 seconds. you should then get confirmation on your iDrive that it's off.
      03-05-2020, 02:43 PM   #13
rickyf10
rickyf10's Avatar
Drives: F80 M3
Definitely gonna do a log but here in Vancouver is rainy... I’m gonna do it when sunny day comes
So here is a little update. 2 o2 bypasses are in place now. Startup this morning seems smooth but still a little fluctuations (within 770-830ish) when rev stablizes around 800. Before startup, I notice that my rail pressure is the same as one in low pressure system (88.4 psi). Is it normal??
      03-05-2020, 03:24 PM   #14
Munchi435i
Munchi435i's Avatar
Might be an odd question but how old is your battery?
      03-05-2020, 03:42 PM   #15
rickyf10
rickyf10's Avatar
Drives: F80 M3
It’s replaced a year ago
      03-28-2020, 12:51 AM   #16
rickyf10
rickyf10's Avatar
Drives: F80 M3
so here is a little update on this. it turned out to be a faulty postcat o2 sensor.
the bank2 post cat o2 sensor sometimes loses voltage significantly (a little question on this: post cat o2 sensor is supposed to be monitor sensor but how come it affects air-fuel ratio ) my mechanic buddy swapped o2 sensors between bank1 and bank2 and the rich fuel mixture problem on bank2 is gone
Thanks everyone here for giving advice!
      03-28-2020, 06:20 AM   #17
Polo08816
Drives: 2014 335i M Sport
If you have BM3, is there an option to disable/ignore the O2 sensor that's post cat?
      03-28-2020, 09:34 PM   #18
rickyf10
rickyf10's Avatar
Drives: F80 M3
I believe you mean “CEL delete”, the one option that removes cat efficiency code from DME. Yes I do have that option for my catless downpipe
