05-28-2020, 11:15 AM | #1 |
Rep 84
EVAP code after catless downpipe
I installed a ER catless dp and I got a code shortly after even though I have o2 readings turned off with bm3. Anyone else get this code and know how to fix it ?
05-31-2020, 11:35 AM | #5 |
Rep 52
05-31-2020, 11:36 AM | #6 |
Rep 52
05-31-2020, 11:37 AM | #7 | |
Rep 84
05-31-2020, 11:41 AM | #8 | |
Rep 52
Odd, since I got mines installed at BMW one would expect a perfect job.. |
05-31-2020, 11:43 AM | #9 | ||
Rep 84
05-31-2020, 11:46 AM | #10 |
Rep 52
06-06-2020, 01:46 PM | #11 |
Rep 52
Did you ever figure out what was wrong? Mine was simple, it was some cap I believe and it is covered under warranty so just have to bring my car back to dealership when the part arrives. Magically the engine light disappeared the day before I took it the dealership but they caught the problem still.
06-15-2020, 09:06 AM | #12 |
Cheapskate
4447
Rep 4,993
EVAP has nothing to do with the downpipe or catalytic converter. It is an emissions requirement to burn fuel vapor. A lot of people get that code. You probably need to replace the valve. It's #1 in this diagram, runs right on top of the intake manifold.
06-15-2020, 04:09 PM | #13 |
Rep 1,452
BMW's DMTL is garbage. Although, that's not the code I got when my fuel breather valve went bad.
2022 CT4-V Blackwing 6-speed
