04-17-2023, 04:07 PM | #1 |
Rep 1,127
Vcx se ista+
Anyone used a VCX SE adapter with ISTA+? It says it's the equivalent of an icom next.
Defang'd link incase people are interested. hxxps://www.vxdiagshop.com/wholesale/vxdiag-vcx-se-bmw-wifi-diagnostic-tool.html |
04-19-2023, 02:56 PM | #3 |
Rep 161
Yes I have one too, it works indeed. Funny enough, I had some issues entering programming mode and the support helped me quite well with it. I did a full istep level update with it. Also normal diagnostics is possible. However both is also possible with a ‘normal’ ENET cable.
zinner559.00 |
02-01-2024, 04:34 PM | #4 | |
Rep 6
vcx-se programming problems
were you able to get vcx-se work with ista im using 4.39.20 i keep getting errors when i enter programming it works grand in diagnostics i know its a oldish post hopefully youll see it thanks |
02-02-2024, 03:35 PM | #5 |
Coding ECU's remotely
445
Rep 1,176
yes
Author of Car Connector - remote ICOM & ENET tool - Built in VPN for easy coding and remote diagnostics
Car Connector on YouTube |
02-03-2024, 07:08 AM | #6 |
Rep 6
wibbles
did you have any problems with it when entering programming in ista and how did you sort it out ?? any help appreciated. ive started doip in vxmanager and it gets vin and all and i have latest vxmanager and bmw icom driver installed it just keeps comming up with the connection to the vehicle is faulty when i try to enter programming and i can run ABL`s in diagnostics |
02-06-2024, 03:12 PM | #8 |
Rep 6
it is .
as ive a power supply hooked up to it and ista shows the voltage and so does the vxmanager, both showing about 13.8 volts roughly jimmert was that your problem that support sorted ? thanks for responding |
