BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Fsc code Generator
      08-29-2014, 09:30 PM   #89
Frogman
Drives: 2012 F30 328i
Originally Posted by digitoe View Post
what's the correct parameter for 2015-1 Premium NA 0x28 0x07?
You can always find out by looking in the Info_Map.imp file.
The region code is 2 bytes at offset 8, and the sequence number is the 2 bytes after that.
Here's an example from the 2015-1 North America NEXT map:
      08-29-2014, 09:34 PM   #90
digitoe
digitoe's Avatar
Drives: 2013 335i
Road Map North America PREMIUM 2015-1 = 0x2D 0x09.
Am I doing something wrong. Every time I try and run fsc, I get the following output.
C:\EC-Apps>fsc.exe NPXXXXX_001B0001.fsc 0x2D 0x09
version after create() = 0xD1.
      08-29-2014, 09:36 PM   #91
digitoe
digitoe's Avatar
Drives: 2013 335i
Where would I find that file at?
      08-29-2014, 09:37 PM   #92
Frogman
You have to b64dec (decode from MIME) the .fsc to binary first. Then feed the binary version to the fsc generator.
The generator only works on the binary version of the FSC.
Binary FSC's are always 319 bytes long.
      08-29-2014, 09:40 PM   #93
Frogman
For 2015-1 NA Premium, it's in the USB1\pkgdb\INFO_MAP_NA_112134_2_12 directory. The # part of the directory may change from region and sequence, so just look for the INFO_MAP_NA_... directory.
The file name can also vary, but it always starts with Info_Map...
      08-29-2014, 09:55 PM   #94
digitoe
digitoe's Avatar
Drives: 2013 335i
Thanks guys, got it working!
      08-29-2014, 09:56 PM   #95
digitoe
digitoe's Avatar
Drives: 2013 335i
Thanks shawnsheridan, got it working!
      08-30-2014, 03:13 PM   #96
david51
david51's Avatar
France
538
Drives: bmw M3 F80
Originally Posted by Dr.Ho View Post
I used this one on my 2012 F30 with CIC, one week ago:
FSC Generator Download
Password: "Eintracht_Frankfurt"
It generates the FSC in three steps. But you have to change the "year-parameter" in the batch-file to a later map (e.g. 2016 - or even later - instead of 2014), then it works perfectly.
The Default 0x06 for 2014 does not work, but 0x09 does!
In adition, you'll need an ENET cable and a working EDIABAS intallation (32-bit - It does not run on 64-bit Windows!)
Look for the intruction Video on Youtube:
thank you very much for the tip Dr.Ho
I managed to update the version Road Map Europe PREMIUM 2014-1
      08-30-2014, 03:20 PM   #97
david51
david51's Avatar
France
538
Drives: bmw M3 F80
pour info
Road Map Europe PREMIUM 2014-1 (last update for gps CIC)
Road Map Europe Next Version 2014-2 (last update for gps NBT)
      08-30-2014, 06:17 PM   #98
HFW003
HFW003's Avatar
5684
Drives: 2024 M340i xdrive
Good morning Gents,
Can someone please let me know of this will work for Oz maps and if so where get I get the maps?
H
      09-04-2014, 12:11 PM   #99
antioedipus
Drives: BMW F10
Or download the new Version, capable of reading CIC and NBT:
FSC Code Generator
Hi there guys, this is a great thread - very informative. Is there possibly a newer version of the generator linked by Dr.Ho, one that includes Road Map Europe Move 2015?
      09-05-2014, 02:22 PM   #100
Darkfiber
Drives: G20 330e
Right, I pulled my FSC with e-sys, base64 encoded it using http://www.motobit.com/util/base64-decoder-encoder.asp
Copy paste into a new file on a SINGLE LINE and save as FXXXXXX_0001B001.fsc for CIC or FXXXXXX_000DE001.fsc for NBT where FXXXXXX is your VIN.
Then downloaded BMW_CIC_NBT_FSC_Generator.rar from
https://mega.co.nz/#F!ugo0HB5L!TPCmejMKPBlRRkz2SDvg0Q
Followed those instructions:
Generating FSC code for CIC systems, copy fsc.exe in the "CIC_FSC" to "tools"
Generating FSC code for NBT systems, copy fsc.exe in the "NBT_FSC" to "tools"
Drag and dropped my base64 encoded FSC into the GUI and selected the correct map, clicked GENERATE.
It didnt work the first time, I didnt put the correct VIN in the file name, this seems important since I changed it to the correct VIN, tried it again and my NAV accepted the code without problems.
      09-09-2014, 09:44 AM   #101
Fabrice26
Drives: BMW X1
Hi,
I am French, and I'm trying with difficulty translating your comments I am very interested.
I understand: It is impossible to generate the activation code card with only the VIN (7 characters)?
You connected your PC to the car with it cable?
Thank you to you.
      09-09-2014, 09:45 AM   #102
shawnsheridan
shawnsheridan's Avatar
Yes, you must to car with Interface cable and read 1B or DE file from Head Unit.
      09-09-2014, 11:57 AM   #103
botho
France
Drives: 2014 F31 330d xDrive Luxury
Originally Posted by Fabrice26 View Post
Hi,
Thank you to you.
Fabrice,
1- Tu dois récupérer la cartographie en premier lieu et la copier sur une clé USB (32 Go minimum).
Pour la dernière carto Europe "Europe_Next_2014-2" pour le GPS PRO (NBT) tu auras donc sur ta clé USB un répertoire du genre "NAVD_000014B9_255_001_048"
Pour te procurer la carto, demande à shawnsheridan qui te filera un lien de téléchargement
2- Tu insères la clé dans ton port USB et tu suis les instructions
3- il va te demander le fameux cade FSC que tu récupères au moyen de 2 logiciels:
a- "SWID_reader" (il y a 2 versions en fonction de ton type de GPS => SWID_1B_reader pour un ancien GPS "CIC" et SWID_DE_reader pour un GPS dernière génération "NBT") te donnera le fichier en ".fsc". Ce logiciel ne fonctionne que connecté à ta voiture au moyen d'un cable ...
b- Ensuite tu utilises le soft "BMW_CIC_NBT_FSC_Generator" dans lequel tu lui précises le fichier fsc et la carte. Il te donnera le code FSC que tu rentreras dans ton GPS en étape 2
      09-10-2014, 02:50 AM   #104
Fabrice26
Drives: BMW X1
Originally Posted by botho View Post
Fabrice,
Merci beaucoup pour ces infos.
J'avais déjà trouvé la carte.... mais apparemment pas la dernière car premium 2014-1.
La version du GPS dépend de la voiture ou de l'année ? dans mon cas un X1 luxe de 2010.
Et pour ce fameux cable, il se trouve facilement ? car après une rapide recherche sur un célèbre site d'enchère je trouve que des cables coutant plusieurs fois le cout d'une mise à jour.
Merci encore (en espérant que je ne pollu pas le forum avec du français).
Fabrice
      09-11-2014, 12:06 PM   #105
botho
France
Fabrice
Check you PM
      09-14-2014, 02:44 PM   #106
spunk
Drives: 2013 335I M-Sport (Manual)
Has anyone here brought their car to the dealer after generating their own FSC code and uploading the latest maps ? I don't want them to void the warranty on my NAV unit :/ . Thanks.
      09-14-2014, 06:03 PM   #107
shawnsheridan
It is not an issue. The FSC Code you generate is identical to that which BMW would provide for you.
      09-24-2014, 06:29 PM   #108
kitster
Drives: G31 M Sport
Finally got it working
Firstly I extracted my DE file using ESys, using Aritaurus post:
Originally Posted by Aritaurus View Post
Just an FYI for those of you who have NBT or can't get SWID reader to work at all.
You can actually grab the 1B or DE file from E-sys by doing the following:
FSC Extended
Base variant 0x63 (For HU_CIC or HU_NBT)
Click Identify
Application ID 0x1B for (App ID 27 for CIC) 0xDE (App ID222 for NBT) <--- This is the App for your Nav enabler
Upgrade Index 0x1
Move Store FSC from the left to the right
Click Read
Click Save and name the file FXXXXXX_0001B001.fsc for CIC or FXXXXXX_000DE001.fsc for NBT where FXXXXXX is your VIN.
I've tried this method for both CIC and NBT and it works.
Then I followed these steps using the BMW_CIC_NBT_FSC_Generator, you will need the NBT.exe in your tools directory (google for the file):
1. Save the FSC file and name the file to XYYYYYY.FSC [XYYYYYY are the last 7 characters of your VIN]
2. Put the FSC-file into same directory as your Base64.exe (in tools directory)
3. Open a command prompt (DOS Screen) and go to this directory (tools directory)
4. Type "Base64 XYYYYYY.FSC XYYYYYY_000DE001.FSC" and press enter
5. Open BMW-FSC-NBT-Generator.exe
6. Click "Browse" and select the FSC file you generated in step 1
7. Choose your map product from the list (For me it was "Road Map EUROPE NEXT 2014-2")
8. Click "Generate"
      09-25-2014, 03:44 PM   #109
mod2133
Drives: BMW 320D EDE (F30)
update maps on i3
I have successfully updated to the latest Europe maps for X3 (2011 with CIC) and F30 (2014 with NBT) using the methods described (e-sys and tools from BMW_CIC_NBT_FSC_Generator.rar) . Many thanks to this great forum.
Now I am trying the same procedure with my friends i3. The procedure seems to works just fine but the code generated is not accepted. Mind you it is the same map that I could successfully load on my own F30.
I would appreciate if anyone can confirm that this method also works on i3. Or do they have their own maps maybe with charging points included (just a wild guess).
Thanks!
      09-27-2014, 12:29 PM   #110
Badboy8813
Badboy8813's Avatar
46
Drives: F06 Frozen SS 2014 M6 CP
Is a token required to run E-sys to grab the 1B or DE file?
'14 F10 CP M5 AW/Full Sakhir Orange, Gloss Black 343Ms, Black IND Cosmetic Package, M Performance CF Diffuser and Spoiler. - SOLD
