12-06-2014, 04:14 PM | #67 |
Rep 40,657
PM sent.
12-07-2014, 09:37 PM | #69 |
Rep 40,657
PM sent.
12-14-2014, 02:59 PM | #72 |
MVP
Rep 32
Drives: BMW F30 XDrive
modify the read FA, VO Code
Hey Shawn,
Got the FA coding to work. I was missing the the apply button in bottom right. Now I want to enable "Activate Enhanced Bluetooth" & "Activate iDrive Office" This is the info I have for Bluetooth MODIFY THE READ FA - Change 6NH to 6NK or 6NS from the vehicle FA. VO CODE - CMB_MEDIA and HU_CIC/HU_ENTRY or HU_NBT For this my question is how do I know if I should change it to 6nk or 6ns. Also for the VO CODE part I am not sure what I should be coding. As for the iDrive Office here is the info and questions I have. MODIFY THE READ FA - Remove Country Controller code (SL8Ax) from the vehicle FA. VO CODE - CMB_MEDIA and HU_CIC/HU_ENTRY or HU_NBT. what if I don't see SL8Ax. what do I VO Code? Thanks in advance as always. PS you have been very helpful and I would be happy to pay if forward. If any body has any questions I have successfully completed the following on my 2015 f30 xdrive Coding DVD in Motion Enabled Rear Fog lights (shaved button) Play Video from USB port Change blinker from 3 to 4 Fog Lights while turning Fogs on with Brights Side Mirrors fold up w/fob or comfort access Windows Go Up w/fob or comfort access Activate Cameras while driving (side, top-view, and reverse) Disabled initial 3 chime seat belt warning Removed Camera Disclaimer Removed initial iDrive disclaimer Allow windows to be rolled up with door open Physical Led door sills kick plate Blacked out kidney grill Last edited by f30mvp; 12-14-2014 at 03:04 PM.. Reason: double typed sentence. |
12-14-2014, 07:12 PM | #73 | |
Rep 40,657
http://f30.bimmerpost.com/forums/sho...65&postcount=9 As written there, if Build Date is >=0713, I would use 6NS. For U.S. car and Office, you do not need to remove country controller. L8A is for China spec car.
12-14-2014, 07:48 PM | #74 | |
MVP
Rep 32
You are the Man!
Thanks for all your help!!! I now get text messages over bluetooth to my car. Thanks Shawn!
-2015 328i XDrive Sport-Black Sapphire Metallic | Leather Dakota Black/Red highlight
-ZSL | 7AC | ZCW | ZDA | ZDB | ZDH | ZLP | ZPP | ZTP | 688 | 8S4 |
12-14-2014, 07:54 PM | #75 |
Rep 40,657
12-14-2014, 08:32 PM | #76 |
MVP
Rep 32
Code default Values
Ok this is a bad one. While coding some how the dreaded "Code default Values" button was hit. for a little i freaked out as it seemed my system was bricked. I then noticed the code button was still highlighted so I clicked on it restored that data and thought everything was fine. I did not click the "code FDL" button. Now when I attempt to connect via E-Sys it does not see my VIN. I have taken backups of the files as I want along each step. I really hope you might have a clue as to what to do because I am kinda back to freaking out a bit. Thanks for any suggestions you may have.
12-14-2014, 08:43 PM | #77 | |
Rep 40,657
Turn car off and wait 30 minutes and try connection again.
12-14-2014, 10:27 PM | #78 |
MVP
Rep 32
Activate High Beam Assistant (Anti Dazzle)
Just tried and you are correct it connected just fine (not sure what happened there).
Do you know of any negative side effects I might see from clicking on that code default button? Also hopefully my last question. I want to code "Activate High Beam Assistant (Anti Dazzle)" it says it requires the vehicle to be equipped with High Beam Assistant. I have the camera on my review mirror if that is what they are referring to. I did not pay the $250 extra for "Automatic High Beams". So not sure It says MODIFY THE READ FA - Remove 5AP from the vehicle FA. VO CODE - FEM_BODY and FLA/KAFAS2 (whichever you are equipped with) I could not find 5AP in the FA but after removing 8S4 I VO CODE FEM_BODY and KAFAS2 just in case. Still don't see a difference. Please let me know if I am missing some thing. Thanks in advance.
12-14-2014, 10:36 PM | #79 | |
Rep 40,657
In your case, without High-Beam Assistant, with the removal of 8S4 you would have only Variable Light Distribution, which is Anti-Dazzle of the Low-Beams. You would not have Glare Free High Beams, which is Anti-Dazzle of the High-Beams.
12-15-2014, 06:44 AM | #81 |
Rep 40,657
PM sent.
12-15-2014, 11:55 AM | #83 |
Rep 13
Looking for all the coding S/W for my two 2014's (F10 M5 Comp & F30 335 xdrv)
Hey Shawn - sent you a PM and not sure if actually made it to your account???
Looking for all the coding S/W for my 2014's - I have a '14 F10 M5 Comp and a '14 F30 335 xDrive. Thanks and I appreciate your help.
M52013UDM |
12-15-2014, 12:32 PM | #84 | |
Rep 40,657
PM sent.
12-22-2014, 05:12 PM | #85 |
Rep 1
12-22-2014, 05:33 PM | #86 | |
Rep 40,657
PM sent.
12-23-2014, 11:28 AM | #88 |
Rep 40,657
PM sent.
