04-03-2018, 04:04 PM | #1 |
Rep 21
Increase Key Fob Distance/Range When Opening/Closing Hardtop F33
You can hold the key fob lock button to put the top up and the unlock button to put the top down but you have to be within 2-3 feet of the car for the function to work. If you step away, it stops.
Anyone have any ideas on how to increase the range? It's annoying having to wait next to the car to put the top up. Same with putting it down. I'd like to be able to start the process while I'm walking to the car instead of standing next to it. Cheers. |
04-03-2018, 04:09 PM | #2 | |
Rep 10,473
Second, You don’t want key FOB to transmit over a large distance as code grabbers are not that rare in today’s environment. |
04-03-2018, 04:12 PM | #3 |
Rep 21
The battery is brand new. In the manual it says I need to be next to the car as well so there's a setting somewhere.
I can unlock the car from 100 feet away; I just can't put the top down or up from that far. |
04-03-2018, 04:14 PM | #4 |
Rep 16,133
I don't have a drop top, but mine opens the sunroof and windows from at least 100 feet away. Try the coding forum, there may be an adjustment possible.
04-03-2018, 11:07 PM | #5 | |
Rep 10,473
You have range issue with your remote and top? |
04-04-2018, 12:37 AM | #6 | ||
Rep 11,760
Drives: 2018 M4 Comp Indv
IK6SPEED4491.00 |
04-04-2018, 11:58 AM | #7 |
Rep 878
It has to be there for safety reasons no? I can lock and unlock my car from a long way away but my key has to be right next to the door before I can start it. Maybe the system is using the key detected aspect to allow the roof to be raised or lowered?
04-04-2018, 10:23 PM | #8 | |
Rep 10,473
04-05-2018, 09:41 AM | #9 |
Rep 21
Maybe his car was coded before he purchased it?
It says in the manual you have to be next to the car to put the hardtop down so his set up is not normal. I want it lol. |
04-05-2018, 01:32 PM | #10 |
Rep 10,473
He purchased a Individual 2018 F83 so his car was not coded anything but stock prior obtaining it several months ago. Likewise, he would had noted above if he had coded it to increase distance.
04-07-2018, 11:51 AM | #12 |
Rep 703
I was able to to this from far away with my SmartTop module (which I happen to have listed for sale in the classifieds section here - returned my M4 lease last week). I'd regularly open/close my top from my office window when the car was down in the parking lot below.
From the SmartTop module manual: Function 5 - Remote Top ( 0=OFF / 1=HOLD / 2=TAP / 3=BOTH ) This function allows full automatic top operation with the original remote fob by pressing the lock and unlock buttons. • Setting 1 (Hold) allows opening and closing of the top by holding down the unlock and lock buttons on the remote. • Setting 2 (Tap) allows opening and closing of the top by tapping the unlock and lock buttons on the remote multiple times. • Setting 3 (Both) allows both of the methods to be used. Top operation with the remote fob using HOLD: • Hold unlock down for about 4 sec: Open the top and bring the windows into the programmed position. • Hold unlock down for about 4 sec, let go and tap open again briefly: Open the top and bring the windows into the opposite position. • Hold lock down for about 4 sec: Close top and windows. • Hold lock down for about 4 sec, let go and tap close again briefly: Close only the top while leaving the windows down. Top operation with the remote fob using TAPS: • Tap unlock 3x in 1 sec intervals: Open the top and bring the windows into the programmed position. • Tap unlock 4x in 1 sec intervals: Open the top and bring the windows into the opposite position this one time. • Tap lock 3x in 1 sec intervals: Close top and windows. • Tap lock 4x in 1 sec intervals: Close only the top while leaving the windows down. |
