07-04-2016, 02:41 PM | #1 |
Rep 50
VTG how to code it ?
Hi.
In my car the VTG module failed, so I replaced it (with used module from ebay). In Rheingold I have three faults regarding VTG: 021908 Encoding: data invalid 02190B Encoding: Transmission failed 48097D Transfer box: Fault, clutch position known, no four wheel drive I was trying to code the VTG with E-sys but there is no such module. The list of modules in E-sys contain only this: How to code this VTG (transferbox) ? |
07-04-2016, 03:06 PM | #2 |
Rep 497
Your going to need ISTA to teach in the clutch and re-initialize. You may even need to reflash using Ista-p to program it with your vin, but thats debatable.
Don't use E sys for programming only coding, your going to need more then that. |
07-04-2016, 07:21 PM | #3 |
Rep 8,364
E-sys has both FDL- and VO-coding as well as ECU (Flash) programming capabilities.
07-04-2016, 08:25 PM | #4 |
Rep 497
07-05-2016, 04:08 AM | #5 |
Rep 50
how this procedure in ISTA-D is called ?
10-09-2017, 12:05 PM | #6 | |
Rep 1
same problem!
Did you solve it? how? I´m in the same situation.. If you have any tip I appreciate..
thank you Quote:
02-28-2019, 08:16 PM | #7 |
Rep 31
