07-25-2018, 10:18 PM | #1 |
Rep 26
another Wheel fitment question
I hate to be that guy but I have searched google and the forums . Even went through the whole aftermarket 19’s thread and can’t find the answer.
I have found 2 sets of rims that I like . But I’m not sure how they will fit also I plan am lowering with springs probably h&r . And I prefer them to be flush or slightly sunk in . First set 19x9.5 et36 all around . I like this set up for he rotation aspect. Second set 19x8.5 et30 19x9.5 et30 If you have either one of these set ups and with pictures that would be amazing Thanks Chris |
07-25-2018, 10:26 PM | #2 |
Rep 4,456
https://f30.bimmerpost.com/forums/sh....php?t=1518065
Here is a good thread with something in between what your looking at. The first set should fit much better with no fender rolling or pulling. The second set you will probably have to do some fender modification and run negative camber in the rear. If it was me I would go with the first set. |
07-27-2018, 10:23 PM | #4 |
Rep 26
I decided the 19x9.5 et 36 prolly won’t work. I happened to have a 18x9.5 et35 and it was only a couple of mm from the strut. And I decided that prolly wasn’t the best of ideas our roads suck and if for any reason I hit pot hole or something and even slightly bend my wheel it will probably also damage the strut
08-28-2018, 09:49 PM | #7 | |
Rep 13
Drives: 2015 428i xDrive GC
08-28-2018, 09:56 PM | #9 |
Rep 13
