BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > How to pass NY state inspection with catless DP
      08-20-2018, 08:43 PM   #67
xrodrigox26
Drives: 2013 335i xdrive fbo
ny inspection
lets try to get back on track to the op, I bought the vrsf dp fix for f30 n55, will be doing a diy to share and let everybody if this will also work for 02 readiness.
      08-23-2018, 10:11 AM   #68
Akricer
Drives: 2018 M550i xDrive
@xrodrigox26:
Pics and a diy would be awesome. I didn't know that the auto code clearing function was removed from the jb4 features. Bought a catless d/p and an intake and got cel's for both.
Thanks in advance
      09-19-2018, 08:09 PM   #69
vympel777
vympel777's Avatar
31
Drives: 540 B58 MSPRT \ F16 5.0 M SPRT
Well did.you try it yet? Been almost a month just wondering if that works.
      09-21-2018, 02:49 AM   #70
ceedawg
ceedawg's Avatar
468
Drives: 2k15 335i xdrive MSport 6spd
Instead of these rig ups I’d go high flow cat to pass NYS inspection. We may have no choice.
2k15 335i Msport xdrive 6spd
Wagner Comp2 FMIC,FTP CP,stock exhaust. Fabspeed Sport catted DP, KW V2 coil overs,FBO BM3 Stg 2
      09-21-2018, 10:55 AM   #71
xrodrigox26
Sorry for late reply.
It worked. The vrsf dp fix got me to only 1 incomplete system for readiness.
I passed inspection. You have to have your jb4 on map0 obviously and sirve the car for 50 miles at least.
      09-21-2018, 11:12 AM   #72
JaredG_F30
JaredG_F30's Avatar
1106
Drives: 2014 335i, M-Sport, Manual
Are you PWG or EWG?
2014 F30 335i, M-Sport, 6MT, V804s, custom exhaust, CTS Turbo Intake & IC, FTP CP, VRSF DP, TMS Strut Brace, BM3 Stg 2, AEM WMI, H&R Sport Springs (381 whp, 429 wtq on Cali 91oct before WMI).
SPI Films Blog/DIY Vids
      09-21-2018, 11:15 AM   #73
xrodrigox26
Originally Posted by JaredG_F30 View Post
Are you PWG or EWG?
Pwg
      09-21-2018, 03:34 PM   #74
XxThe_RemedyXx
XxThe_RemedyXx's Avatar
967
Drives: 2016 340i xDrive
I have Bootmod3 flashed. I believe it also leaves 1 incomplete system for readiness as well. If so, BM3 users should be ready to go?
      09-21-2018, 03:37 PM   #75
xrodrigox26
I have Bootmod3 flashed. I believe it also leave 1 incomplete system for readiness as well. If so, BM3 users should be ready to go?
Not entirely sure on that. I was on jb4 only. Map0 and drove about 50-60 miles after installing the dp fix.
If that's the case with bm3 that's cool feature.
      09-21-2018, 03:51 PM   #76
XxThe_RemedyXx
967
Cool man glad it worked!
      09-21-2018, 06:51 PM   #77
vympel777
vympel777's Avatar
31
Interesting i dont have jb4 but got ecu professinally tuned. No check lights so far. Is there a way to install that vrsf fix without jb4?
      09-21-2018, 08:15 PM   #78
XxThe_RemedyXx
967
You dont need JB4 for the DP fix.
      09-22-2018, 02:22 PM   #79
Mike.
Mike: Everyone's Pal
Mike.'s Avatar
Drives: F80 M3
2013 BMW 335xi  [10.00]
you can pass with one monitor not ready, or figure out a way to force the monitors to show ready w/ an ecu flash.
you can also do a DP fix, but they are waaaay harder to get working on EWG cars.
Alpine MSS Stage 2+ E30 tune|MST Intakes|VRSF Single Mid Pipe|Agency Power Intercooler|VTT Full solution crank hub fix
      12-25-2018, 06:40 PM   #80
F30NFifty5
Drives: F30 335i XDrive 6mt / e83 X3
Originally Posted by Jadar View Post
Had anyone has issues with sport cat/hiflo downpipes and passing emissions or having the car be in ready mode?
Curious cuz I'll be switching back to a catted dp! I can't stand the damn awful smell anymore!
VRSF catted DP gave me a check engine light
      12-27-2018, 09:06 PM   #81
$howtime456
$howtime456's Avatar
301
Drives: BMW 640i
For whoever needs to pass inspection hit up ENZO. I tried the VRSF and it made my monitors complete after a couple of miles but threw a check engine light on stg1. and Stock map. Went to ENZO and i was good to go.
N55 GENERAL
David Shoup Tuned
Fully Built By Miami Engines/Project Motorworks
Precision 6266 On Steroids
      04-18-2019, 09:19 AM   #82
cjacky
Drives: 2014 BMW 328i xdrive
I couldn't pass inspection last year but I need to renew my registration soon so is there anyway of passing or would I have to put the stock dp back on? I have rk tunes and ER catless dp.
      02-25-2020, 03:58 PM   #83
BXMSport25
BXMSport25's Avatar
Drives: 2017 BMW M3 Competition DCT
Im running into the same problem.
Do you mind sharing how you fixed it?
      02-27-2020, 08:13 AM   #84
jcarv20
Drives: 2014 435i
Not to jack the thread but are CT emissions (ny neighbor) the same?
      02-27-2020, 11:24 AM   #85
thejeremyman9
thejeremyman9's Avatar
4364
Drives: 2015 BMW 335i
You should probably just google this and find out for yourself instead of asking here....
      03-03-2020, 10:25 AM   #86
XxThe_RemedyXx
967
Nothing you can do to pass NYS inspection with a catless DP. I tried everything under the stars. I wound up removing DP, installing OEM DP, passing, then installing catless DP back. Make sure you swap your gaskets each time.
      03-11-2020, 03:28 PM   #87
BXMSport25
BXMSport25's Avatar
Not true. like one of the other poster's mentioned - Go See Enzo @ Enzo performance.
      03-11-2020, 05:13 PM   #88
Mike.
Mike.'s Avatar
Drives: F80 M3
there is always a way!
