10-21-2018, 12:22 AM | #1 |
Rep 76
442m 19 inch square tire size for winter driving
I decided I will not entirely want to park my 17 340i this winter...i'd like to occasionally drive it throughout the upcoming winter.
i drive a range rover in the winter but when roads are bare and dry up here in Canada i'd like to drive my 340i...i know some of you will suggest buying a set of 18 inch winter wheels. I wanna keep the look of the car the same what square tire size should I go with that would fit on the stock 19 inch 442 m wheels?? staggered winter tire set seems hard to find...well unless if i pay a fortune for sottozeros lol |
10-21-2018, 01:33 AM | #2 | |
Rep 1,827
2013 F30 335i RWD ZF Melbourne Red
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~ |
10-21-2018, 11:00 AM | #3 | ||
Rep 76
well I like the look of the rims...i may ditch the run flats all together and later in the spring maybe buy a set of 437m wheels. mounting and balancing every season is not an issue for me as my brother owns a shop lol |
10-21-2018, 11:37 AM | #4 |
Rep 4,318
442m are 19x8 +36 and 19x8.5 +47. you can run 235/40/19 square, perfect on 8", slight stretch on 8.5"... or 245/35/19, slight bulge on 8", perfect fit on 8.5". personally i'd go with 235/40/19 square because it is narrower and taller.
10-21-2018, 11:55 AM | #5 |
Rep 16,060
alohasurftoad3075.00 |
10-21-2018, 12:06 PM | #6 |
Rep 4,659
I wouldn't be that concerned with driving over pot holes in the winter - assuming you're also using the same set or same size for the summer. If the road is bare, you're still driving over the same roads with or without potholes. In the winter, at least the potholes will be filled with snow. I'd be more concerned with the low profile/width of the tire where a narrow tire is more preferable (again, assuming the tire specs are different on the 18" than 19").
10-21-2018, 12:14 PM | #7 | |
Rep 76
10-21-2018, 12:15 PM | #8 | |
Rep 76
10-21-2018, 12:18 PM | #9 |
Rep 76
there would be no issues with driving on slightly stretched tires?? i will mostly be driving on highway in the winter with this car..
10-21-2018, 01:35 PM | #10 | ||
Rep 4,659
10-21-2018, 01:39 PM | #11 | |||
Rep 76
i did find a set of oem sized 19 inch staggered kumho winter craft wp72 so that would be an option if I don't go with a square 19 inch setup. |
10-21-2018, 03:21 PM | #12 |
Rep 2,294
Likewise, running this size on both 340s I have/had. For winter, the 18s are a better size, IMO. Up to you, though.
2018 340i xDrive M Perf Edtn Sunset Orange
Previous BMWs - 19 others since 1971. |
10-21-2018, 03:56 PM | #13 |
Rep 596
I run this size winter rubber on my 440xi vert. Agree 18's are a better choice for winter.
2020 X3 M40 Alpine White over Cognac • 20" BBS CC-R • Cerium delete
2017 440xi Estoril over Saddle Brown • 6-speed • Every stinkin' option |
10-21-2018, 04:32 PM | #14 |
Rep 16,060
Narrow 18s at that. Wider tires tend to float more above the snow rather than push it aside to reach the road surface. If you have an alternate vehicle that's better in snow when you need it all well and good, but there's a certain Mr. Murphy who created a law that deals with said situation.
10-22-2018, 11:35 AM | #15 |
Rep 446
Hi! Im also in canada and just swapped out my 442m from summers to all seasons. I changed to Continental DWS06 235/45 front and 255/35 back. feels great! dont forget to add +3 psi to compensate the softer sidwwalls
Mod bug will bite you if you buy a BMW ================================= |
10-22-2018, 11:42 AM | #16 |
Rep 57
This is what performance winter tires seem to be good at. If you're only going to be driving on bare dry - but cold - pavement, that's what you want.
Now: 2023 i4 M50 (Portimao Blue over Mocha)
Previous: 2017 F31 330i xDrive Touring (Estoril Blue, M Sport, Prem Pkg Enh, etc) |
10-22-2018, 12:51 PM | #17 | |
Rep 76
V rated 19 inch tire like the kumhos seem to be a best fit for me. great info from all the members here though. |
10-22-2018, 02:34 PM | #18 |
Rep 255
I use 18x8.0 square setup for winter vs the staggered setup for summer. The extra performance on snow tires is neither practical nor economical.
2011 X5 xDrive 50i - retired
2016 340i xDrive - retired 2020 M4 Coupe |
