BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > Need brake torque specs
proTUNING Freaks
      11-05-2020, 07:59 PM   #1
Solidjake
¯\_(ツ)_/¯
Solidjake's Avatar
Poland
945
Drives: '13 328i Msport 6MT
Well....since the TIS is gone I can't find a source for various torque specs on the F30. I need need the caliper bolt and guide pin torque values for FRONT 335 GREY BREMBO calipers and REAR 328 STOCK 1 PISTON calipers.
Thanks!
Apex SM-10/DWS06+ | 400m/X-ice Xi3 | Injen Exhaust | Stoptech SS Lines | 335 Front Brakes
Hawk HPS 5.0 | RBF600 | ER Charge Pipes | Wagner Evo Comp 2 FMIC
      11-17-2020, 01:13 PM   #2
oceanview
oceanview's Avatar
Switzerland
207
Drives: 335i F31 RWD Autom.
Ugh, nasty! Loved NewTIS
Found it as picture in a German Forum
Front Caliper M12x1.5 -> 110 Nm
Rear Caliper M12x1.5 -> 30 Nm and then add 90 Degrees
Guide Pin Front and Rear 28 Nm
https://www.motor-talk.de/bilder/dre...208133236.html
335i F31 RWD in SB || Powertrain: Active Autowerke Flash Tune Stage 1 | AA Charge Pipe | AA FMIC | GFB DV+ | xHD Trans-Flash | Quaife LSD | Cyba 3.5" Carbon tips || Chassis: 20" 405M | Wiechers Strut Bar | Rear M-Diffusor || Brakes: 18" M-Perf Brake orange 370/345 | EBC YellowStuff pads all around || Various: LED bulbs: Fog-L. front | Turn Signal f&r | Brake L. | Reverse L. | Rear L. | Rear Fog L.
Solidjake945.00
F32Fleet3571.50
      11-19-2020, 01:49 AM   #3
andrew3series
Drives: BMW 340i xDrive
would u happen to know the brake torque specs for M performance brakes? (2 piston brembo rears)
      11-19-2020, 05:41 PM   #4
Logicoeur
Logicoeur's Avatar
991
Drives: F30 335i xDrive
It's the same bolt. Same specs.
      11-25-2020, 08:29 PM   #5
bthomas518
Drives: 2016 228i
Heads up, the rear caliper bracket bolts are TTY (torque to yield), you should replace them every time you loosen.
And you'll want to make sure the car is jacked up nice and high, it was a nightmare getting those off on my car on Esco jack-stands set at a lower position. Wasn't enough clearance to get a breaker bar on them and not enough room for an impact gun.
      01-13-2021, 01:04 PM   #6
GreenF30N26
GreenF30N26's Avatar
153
Drives: F30 328ix N26
I'm about to do the rear brakes on my 2016 328ix LCI single piston and found this post that confirms the details above with a screen shot in English from TIS
https://f30.bimmerpost.com/forums/sh....php?t=1354470
Seems like you are not supposed to turn an extra 90 degrees if you reuse the M12x1.5 bolt, but as bthomas518 mentioned the repair guide says they should be replaced.
      01-15-2021, 07:27 PM   #7
WallySlash
WallySlash's Avatar
Drives: 2014 428xi Sport Line
2014 BMW 428xi  [9.00]
I can still get on the TIS site. I had to register but still can access.
