01-18-2021, 05:25 AM | #1 |
Rep 140
Translation problem with E-sys on F30
Very good
I am already somewhat "rusty" with these issues, which I had almost forgotten. The fact is that I have tried to connect with the F30 and I have not been able. The problem is that when selecting the model to proceed with the connection, the F30 does not appear and if I enter with F20 I access and read the modules, but then I do not find any of the things that I want to modify. The truth is that I no longer remember if F30 had to appear in the drop-down, or it was entered with another model. Any ideas? Last edited by jaco_ma; 01-23-2021 at 02:06 PM.. |
01-18-2021, 05:45 AM | #2 |
New BMW owner
139
Rep 621
Drives: BMW 316d, BMW F40 116d
The F30 belongs to the F20 group.
Whatever you’re looking for is there, there is no FRM like in the F10 for example. What are you searching for that you can’t find? |
jaco_ma28.00 |
01-18-2021, 07:51 AM | #3 |
Rep 140
01-18-2021, 08:36 AM | #4 |
Rep 140
I have tried again with the two options of F20 and apparently I access and read the encoding, but when I access it it is "unreadable" I cannot find any of the options.
01-18-2021, 10:45 AM | #6 |
Rep 2,302
I think your E-Sys 3.27 is too old for your newest psdzdata.
So try a newer Version of E-Sys or older psdzdata. https://f30.bimmerpost.com/forums/sh...12&postcount=3 |
01-18-2021, 11:42 AM | #7 | |
Rep 140
So I uninstall E-sys 3.27.1 and install from its link E-sys 3.30 while keeping E-Sys Launcher PRO? Or I substitute for the PSdZData .4.25.40. by v. 4.16.30 to see if it works like this? Last edited by jaco_ma; 01-18-2021 at 11:55 AM.. |
01-18-2021, 12:29 PM | #8 | |
Rep 2,302
And also keep E-Sys 3.27. Install E-Sys 3.30 and when you start Launcher Pro use it with E-Sys 3.30. |
01-18-2021, 12:59 PM | #9 |
Rep 140
01-18-2021, 01:29 PM | #10 |
Rep 2,302
01-18-2021, 03:00 PM | #11 |
Rep 140
I don't know, it won't let me have more than one version of the same program.
I have uninstalled v.3.27.1 and installed 3.30 with the same result. Tomorrow I will reinstall everything from scratch and comment on the result. |
01-18-2021, 03:31 PM | #12 | |
Rep 2,302
You have to specify a separate folder for each E-Sys during installation. Then it also works with the multiple installation. So there may not be 2 versions in one E-Sys folder, but you name e.g. a folder E-Sys 3.30 and install into there. And then i just did a test with E-Sys 3.27/E-Sys 3.30, the same launcher and the newest psdzdata and it worked without problems. So i have no other idea what's wrong. May be it helps to install everything new as you intend to do. |
jaco_ma28.00 |
01-22-2021, 03:28 PM | #13 |
Rep 140
I will also try mounting different E-sys in different folders.
On the other hand, E-Sys Launcher PRO 2.8.2_Build_162 BFU Xode Edition, by TokenMaster, is it still functional? Let's see if that is going to be my fault. |
01-23-2021, 02:04 PM | #16 |
Rep 140
I've reinstalled everything and I'm still the same. I don't know where to go anymore.
And above all, I wanted to get up to speed on the G20 coding. Last edited by jaco_ma; 01-23-2021 at 02:30 PM.. |
01-23-2021, 03:22 PM | #17 | |
Rep 2,302
If you want to code a G20 i think you need a newer Launcher. |
jaco_ma28.00 |
01-24-2021, 07:21 AM | #18 |
Rep 140
Thank you very much for your offer.
What I need to code in the F30, a partner has done for me with Bimmercode. Getting E-sys to work was almost a personal challenge, stubborn. For the G20 I will have to catch up a bit. Are all the Launchers that currently work in the G20 paid? Thanks again and best regards. |
01-24-2021, 07:56 AM | #19 | |
Rep 2,302
jaco_ma28.00 |
01-24-2021, 07:58 AM | #20 |
Rep 140
01-25-2021, 01:44 AM | #21 | |
Rep 523
Reagars Last edited by Siki78; 01-25-2021 at 01:49 AM.. |
jaco_ma28.00 |
01-25-2021, 02:50 AM | #22 |
Rep 140
