10-09-2021, 06:54 PM | #1 |
Rep 1,381
Custom LCI icon headlights modded
Embarked on my bravest mod yet, cutting open my retrofitted icons to fit addressable RGBW lens behind the DRL's, plus create a functioning eyebrow (LCI deletes this from factory).
I have brand new OEM grade lenses so seperating them will be easy.. cut the majority of the lens middle out, then create a notch in the left over lens and slowly pry it out using heat to make the housing edges flexible. Permaseal does NOT ease underheat only the housing does, I used the heatgun with a focus attachment to make it possible for me to fit a rivet popper tool under and break the seal, all you have to do then is pull at the sharp edge of the lens and it lifts out. Fast forward a few days after reverse engineering the design, dremeling a lot of holes and gaps in trims, I came to wiring up my LED controller. I have 2 relay switches to power this. One is triggered by the headlight/ecu.. I posi tapped this from one of the original DRL boards The second relay uses a delay function so that even though the DRL might have down powered the LED controller still has 5 seconds of life left to perform the shutdown led animation. Demo animation 01: https://streamable.com/5iognm Demo animation 02: https://streamable.com/mhetkg Demo animation 03: https://streamable.com/qpzue1 Demo animation 03: https://streamable.com/1x13t0 Because the LEDs are addressable all you have to do is wire a pos, neg and data wire to each strip.. you configure where the group splits need to be via the bluetooth app, so for example DRL #1 might only use 26 chips, DRL #2 might use 38 and the eyebrow might use 65. You input all the correct information and then set offset delays and priorities as to which order they run, or group them together. --- I will update this thread as the build continues.
2015 435i - 401whp
Scorpion catless dp, VRSF 6.5" HD FMIC, MST V2 inlet, NGK 97506, MHD Stage 2+ 102, xHP Stage 3, M Performance Exhaust (modified for valved straight thru) |
10-09-2021, 07:58 PM | #2 |
Rep 1,381
2015 435i - 401whp
Scorpion catless dp, VRSF 6.5" HD FMIC, MST V2 inlet, NGK 97506, MHD Stage 2+ 102, xHP Stage 3, M Performance Exhaust (modified for valved straight thru) Last edited by fortythirtyfive; 10-10-2021 at 01:58 PM.. |
10-15-2021, 02:27 PM | #4 |
Rep 769
I was ready to talk shit but that is 100% fire. Looks awesome. Put some socks on.
fortythirtyfive639.50 |
10-20-2021, 12:40 PM | #6 | ||
Rep 1,381
I can also report back that I've driven with the passenger headlight in for just over a week, in both dry and wet conditions with zero condensation! I used a small amount of butyl rubber at first but felt I had skimped too much, so I heated the lens up, popped it out and back filled the channel with butyl. I then used a small amount of silicon gasket sealant on the separation line between headlight and lens to be super safe. What is incredibly annoying is I forgot to reinsert the big silica gel packs during the second lens fitting, luckily it looks like I might not need them. The original indicator LED is currently showing that's why it jumps a bit in the top right corner.. I just need to make some plastic to cover the LED board. As I'm sure you can all guess they're nowhere near as bright as OEM, if anything though those were dazzlingly bright due to how the plastic reflectors are placed on the DRL acrylics
2015 435i - 401whp
10-22-2021, 05:20 AM | #8 | |
Rep 1,381
I'm hoping to get some boards built with the leds already on them, that way I don't have to do crazy offsets with the individual leds to make the corners seamless (you can't bend led tape) plus it'll save with all the crazy wires coming out of each led strip. Currently all the wiring is in thew way of the adaptive cone/reflector and as a fail safe the car has shut down all adaptiveness, that doesn't overly bother me though as split beam function never worked amazingly for me. I still need to do the second headlight asap, as life goes at the moment though I've had a ton of other things pop up that's causing me delays lol, I keep starting projects and never find the time to finish the damn things. I'm moving at the end of November though so everything has to be tied up and finished by then.
2015 435i - 401whp
10-23-2021, 04:16 AM | #9 |
Rep 208
These are insane😳 not sure on the multicolour in the video but the start up animations look amazing. Fair play to you I can imagine alot of hard work went into that
10-30-2021, 09:08 AM | #10 | |
Rep 4
F31 328i 2014 N20
E46 320i 1999 M52B20TU |
11-01-2021, 10:51 AM | #11 |
Troopa
63
Rep 85
The lighting effects are amazing! Awesome work!
EBII F30 340i Shadow Edition |
11-03-2021, 10:30 AM | #12 |
Rep 327
You ever look at something that a person is able to accomplish and just think, "wow they're just a more advanced human than me". This is one of those moments.
I've always shied away from electronics/soldering/circuitry, mostly because I'm too dumb to understand it. That, and I tried to pry open headlights years ago without the proper tools and vowed to never do it again. Great job here. |
