03-25-2018, 11:41 PM | #1 |
Rep 394
BMW M Performance big brake kit 2,3 and 4 series RED
F2x 2 Series, F3x 3 & 4 Series M Performance Brake Kit - Red - BMW (34-11-2-221-445) Brand new and never installed. Everything you see pictured is included.. mounting hardware and all. I'm located in Queens NY. Picked these up from a forum member recently but I've decided to get new H&R springs and new tires instead. I prefer a local pickup but will ship at buyer's expense. REAR ROTORS ARE NOT INCLUDED. F2x 2 Series, F3x 3 & 4 Series M Performance Brake Kit - Red. *Rear rotors sold separately. **Requires at least 18" rims. Brembo high-performance 4-piston aluminum fixed caliper on the front axle and 2-piston aluminum fixed caliper on the rear axle. M logo on the outside of the caliper. Improved thermal resistance thanks to larger, internally-vented lightweight construction sports brake discs. Cross-drilled and grooved brake discs also reduce water film build-up between the brake lining and the disc surface. Drilled and grooved, internally-vented lightweight brake discs with riveted aluminum hat measuring 370 x 30 mm (diameter x thickness) on the front axle and 345 x 24 mm on the rear axle . Last edited by lazyninja87; 03-29-2018 at 08:20 AM.. Reason: revised price |
03-28-2018, 02:40 PM | #3 |
Rep 3,032
Bump
Next to body kit, best upgrade I ever did, buy with confidence folks.
2016 BMW F80 ZCP
Instagram : 7IM3LESS https://instagram.com/7im3less?igshid=YmMyMTA2M2Y= |
03-28-2018, 05:13 PM | #4 |
Rep 394
03-28-2018, 06:42 PM | #5 |
Rep 3,032
Yeah suspension is next for me too although I'm consider Dinan springs myself
2016 BMW F80 ZCP
03-30-2018, 03:11 PM | #7 |
Rep 3,032
Bump
2016 BMW F80 ZCP
ArizonaErik95.00 lazyninja87105.00 |
04-02-2018, 07:47 PM | #11 |
335i F30
68
Rep 252
Are calipers included?
13' F30 335i Mineral White Metallic
Sport Package | 19" Rotiform SPF | BC Coilovers Coral Red Interior | H/K Package Active Autowerke Flash Tune, FMIC, Exhaust | BMS Intake | VRSF DP | VRSF CP |
04-05-2018, 02:05 PM | #15 | |
Rep 394
Sounds good.. I've gotten a few PMs but it doesn't seem like people are very serious. If I have them mid April still they're yours |
04-07-2018, 03:25 PM | #16 |
Rep 2,152
Bump for a great price. Oem Brembos front and rear for less than 2k folks! After purchase of rear rotors.
lazyninja87105.00 |
