07-22-2021, 12:52 PM | #1453 |
Rep 122
Yes
Mods: 19" HRE FF15, M Performance diffuser, Bilstein B16 Damptronic, VRSF catted downpipe, Remus catback, Dorch St1, Pure 800, OS Giken LSD, Ross Racing PCV+OCC V1
07-22-2021, 12:56 PM | #1454 | |
Rep 59
07-22-2021, 07:28 PM | #1457 | |
Rep 41
08-07-2021, 03:17 PM | #1458 |
Rep 53
Apologies if I missed this somewhere but I’m preparing to purchase BM3. While reading the website I noticed it said:
“ Vehicles with November 2019+ software may require DME unlock done on the bench to enable OBD flashing. If you have the November 2019+ software update, feel free to contact support@protuningfreaks.com for details.” I have a 18 440i GC and last had it serviced (oil change) in the winter. Just wondering how would I find out what software I’m running so I can avoid prolonged issues. Thanks. |
08-07-2021, 09:46 PM | #1459 | |
Rep 732
08-08-2021, 11:15 PM | #1460 |
Rep 53
08-09-2021, 06:59 AM | #1461 |
Rep 122
For software id's see the screenshots in chapter 2 of the BM3 manual: https://bootmod3.atlassian.net/wiki/...R%20MANUAL.pdf
08-09-2021, 12:54 PM | #1462 |
Rep 223
just purchased and flashed stage 1 91 last night. I flashed from my samsung s9, using enet cable and a usb-c to ethernet adapter.
it worked perfectly, and only took about 5 minutes. a good tip is to download the map you are going to flash, and then flash it from your downloaded maps. this way, it's not using the internet to download and flash at the same time, which speeds things up a lot. the car is so fast now (using petro canada 94). the throttle is pretty sensitive in comfort/sport/sport +. I wish the throttle was a little more gradual in comfort, starts off ok and then just launches, if you're not careful, but it's not really a big deal. I did get my software IDs and sent them to PTF before I purchased, just to check and make sure. definitely recommend folks to do that before buying. PTF is really quick on their support tickets and get back in an hour or two, even late at night they got back to me right away. at this point i'm not sure what gas I should run, what i can get away with etc. I assume if i run the stage 1 93 map, i should stick to petro 94, but with the 91 map, should i stick to 93+? can i get away with costco 91 from time to time? |
08-10-2021, 08:30 AM | #1463 |
Rep 611
I faced the same, the car became too hyperactive, especially in the city. The xHP tranny flash alone helps, and enabling the launch in 2nd gear in comfort is perfect for that.
08-14-2021, 03:00 PM | #1464 | |
Rep 223
08-15-2021, 09:19 AM | #1465 | |
Rep 4,871
But, if you aren't laying into it in lower gears (and hitting limits), or want those firmer shifts, no real need to get xHP. |
08-19-2021, 08:21 AM | #1467 |
Rep 126
I have a 2018 G01, been using the b58, stage 1 bm3 tune for the 3 years I've had it. Love it. Going to trade in for the 2022 LCI version in about a month. Any info on compatibility on this updated B58? Forgive me if this has been asked before! Thank you!
08-19-2021, 05:20 PM | #1468 |
Rep 1,452
Anyone running an upgraded turbo on the OTS maps? Pure800/VTT GC/etc? I know it'll run fine but wondering how much better it holds the power to redline.
2022 CT4-V Blackwing 6-speed
540iSUP703.00 |
09-09-2021, 09:12 PM | #1469 |
Rep 565
Drives: G20 M340i
11-26-2021, 05:26 AM | #1470 |
Rep 799
11-26-2021, 07:31 PM | #1472 |
Rep 180
What are the major downsides of using anti-lag?
AFE Filter | BMS Intake Pipe
CTS DP | CTS CP | CTS Heat Exchanger PTP Turbo Blanket | AEM WMI Kit | Custom Exhaust PJ ACN91 + Meth tune| XHP Stage 3 |
11-27-2021, 04:20 PM | #1473 |
Alexander Hartunian
58
Rep 95
Drives: 2018 BMW 440i
They have released all this but haven't released a flash unlock for the DME yet? The new i-level software has been cracked, but not released… Is there talk of PTF releasing an update so we don't have to send our ECU in and lose ability to drive for 2 weeks?
2018 F32 440i - Black Sapphire Metallic - KW Suspensions V1 | VRP Intake | VRSF Catless Downpipe | Dorch Stage 2 HPFP | MHD OTS Stage 2 E40
11-28-2021, 09:13 AM | #1474 |
Rep 799
bm3, bootmod3 |
