08-15-2021, 11:53 AM | #23 | |
Rep 10,256
Every vehicle component subject to continuous wear-and-tear has a useful lifespan which depends on road conditions and driving style. If the punctured left rear tire has to be replaced, it might sense to replace both tires if the tread on the right rear tire is close to the end of its useful lifespan. For tires, the decision whether to replace in pairs is more straightforward. For struts, it's a bit more difficult because the useful lifespan can vary greatly. If one of the struts failed at 10K miles, I would replace one strut. If one of the struts failed at 70K miles, I would replace all four struts. My own opinion only - not a recommendation. There are no fixed rules in this case. Only the owner's perspective matters on the value of spending more money to avoid multiple service visits later. Time is after all money. |
alohasurftoad3078.00 |
08-20-2021, 02:03 PM | #24 |
Rep 133
Drives: F32 435dx
Warranty replacement is a completely different thing. No dealership will replace you nothing else than what is defect. But IMHO shocks cannot be treated the way e.g. lights are.
Of course, it's a different thing if one shock is broken after 5K miles, 25K miles or 70K miles. Personally, if one shock was broken after 20-25K miles, even if it was replaced under warranty, I would ask to replace at least the other one in the same axle too. That would result in a more uniform behaviour by the car. If it was broken after 5K miles, then ok, I would replace only the broken one, since there's no significant wear on the reamining shock. There are shops where you can measure the wear and responsiveness of each shock (while on the car). I wouldn't be happy to have a completely new 100% performing shock on one wheel and a 60% performing shock (which is still acceptable and doesn't need replacement) on the other wheel. So, the most economical solution is to replace both shocks on the same axle, if not all of them. Bottom line is that what each owner does, relies truely on his/her perspective on things, as cfm56d7b states. |
10-20-2021, 11:01 AM | #25 |
M340i
393
Rep 968
Drives: BMW M340i
There is something unique to BMW: They fall apart after the warranty expires!!!
07-12-2022, 04:12 PM | #26 |
Rep 1,369
The issue with springs is they are paired to dampers. Unless you are going BMW OE, any other damper will have a different compression/rebound rate compared to the BMW OE. Is the difference significant? Depends on what damper you choose.
johnung4528.00 |
07-13-2022, 07:18 AM | #27 |
Rep 785
I'm with you on that, but I was referring to the posts about replacing springs because they have 60k or more miles on them. In all the years of owning cars I've never even had a shady mechanic try to sell me new springs because they were worn. It wasn't until I read threads like this that I heard people suggest new springs because they are cheap parts. I really don't think that's necessary unless they're damaged or you fit different shocks that are poorly matched with oem springs.
335i rwd auto, 2015 with m performance LSD and Dinan stage 2. Cts charge pipe, mad 5" stepped intercooler.
johnung4528.00 |
07-20-2022, 08:46 AM | #28 | |
Rep 1,369
Jvac432.00 |
