BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Suspension Alignment questions
Studio RSR
      10-01-2021, 06:45 PM   #1
djacinto
djacinto's Avatar
Drives: F32 428i Xdrive
2014 BMW 428i xdrive  [0.00]
2013 128i  [0.00]
Hey y'all
was creating a service and purchase history book for my car and was taking a look at my previous alignment sheet from back in June. I had gotten an alignment since I hadn't had one since getting the car, as well as I had replaced my lower control arms, swapped wheels and added spacers, so thought it might have been time for one
On the service receipt, it said "Further parts replacement required to correct camber issue" Having a look at the alignment values post-fix, it seems just the driver side front is just
View post on imgur.com
. It's not something I am actually worried about since driving the car the past few months there hasn't been a reason for me to be concerned.
So onto the actual question, What needs to be replaced or what can I do to sort of fix this myself?
Is this something I should be concerned about?
Thanks in advance y'all!
      10-02-2021, 09:01 AM   #2
Lancelot
France
568
Drives: 2017 m550i
0'30'' degrees is not a big issue, but tbh it's the passenger one that should be fixed to have (at least) -0'30'', these cars are not fun to drive with zero camber :-/
2017 M550i | Sophistograu
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i
djacinto373.00
      10-02-2021, 09:17 AM   #3
JonTheGreek
Drives: 13 BMW 335i
It sounds like you might benefit from K-Mac's front adjustable camber bushing.
https://www.vividracing.com/kmac-fro...152459126.html
djacinto373.00
      10-02-2021, 09:34 AM   #4
djacinto
djacinto's Avatar
2013 128i  [0.00]
Ha ha I agree lol!
The car has been much better to drive since replacing the leaking lca's but I know it could be better, like you said, with just a tad more camber!!
-2014 F32 428i Xdrive "Bella"
Follow the build!
-2013 E82 128i "Austin"
Follow the build
EuroFever
      10-08-2021, 10:37 AM   #5
djacinto
djacinto's Avatar
2013 128i  [0.00]
Blank
Curious, I'm interested! Are these ok to use with xdrive?
Follow the build!
Follow the build
EuroFever
      10-16-2021, 09:17 AM   #6
JonTheGreek
Drives: 13 BMW 335i
Not sure about xdrive as I have rwd. Try to contact them and see. Sorry I couldn't be any help.
If the control arms have the same part number I would assume so. Another way to know is if the mounting part has the same dimensions.
djacinto373.00
      10-16-2021, 09:56 AM   #7
djacinto
djacinto's Avatar
2013 128i  [0.00]
Thanks man will definitely check them out!
Follow the build!
Follow the build
EuroFever
