05-11-2020, 05:38 AM | #67 | ||
Rep 940
Helpful info. Does this E10-20-031-18-22 kit also work for 2016 435 xDrive Gran Coupe? The euro part # guide doesn't list out any compatible Eibach springs for my car.
2013 e92 M3
2011 X5 35d 2018 F80 M3 ZCP |
08-25-2020, 01:44 PM | #68 |
Rep 177
I am putting together my own "B12 kit" by getting a set of Bilstein B8s shocks and Eibach 05-22 springs. Ordered the gently used B8s from the classifieds and the springs from Amazon UK (cheapest I found). This will go on my 2016 335i GT (F34).
Should I get some E60 or F8x rear bump stops for good measure, as suggested by FaRKle? Also are the stock strut mounts still good to reuse at 50k? This thread along with a few others have really helped me make the choice. TIA! |
08-26-2020, 02:44 PM | #69 | |
Rep 40
09-16-2020, 02:43 PM | #70 | |
Rep 16
The B12 is a good set up if you're just looking to lower the horrible X-drive ride and stiffen up the suspension. It transforms the car in that aspect, and brings it inline with standard Msport suspension, although a tiny bit stiffer. Driving is a lot better, but far from perfect. Its a great set up for daily drives, fast highway speeds and light cornering. The B8 struts are awesome in that aspect, they dampen the road pretty well at high speeds, but for me the springs are the let down. They are little bit too soft for me. Still lot better then OE but still soft. I wish they were more progressive. But hey, that all you get with B12.. Next step is B14 if you want what b12 lacks of. At this stage, a year later, I'm looking to upgrade again. I want B16 really so I can play with adjustments,drive faster around the corners, have even more stability but they come at the price. I might just go with B14.. So in summary: B12 if you want upgrade from stock, lower and stiffer the ride, but with some sort of comfort in mind. Great for dailys and fast highway driving B14 less comfort, stiffer ride,can lower the car even more, progressive springs more suited for fast roads, corners and even trackdays.. |
01-05-2021, 12:26 PM | #71 |
Rep 11
Eibach pro or sportline
I have been looking to upgrade for a while and I am considering the B12. As I see it there are two B12 options: Pro or Sportline. Same shocks but different height of the springs/lowering. Either 30-25/25 or 40-35/35 (sometimes it says (30/30 and 40/40). All threads and pictures online only even shows and talks about the pro kit and am REALLY curious about the Sportline because in theory at least it should be firmer than the pro kit.
I am looking to upgrade my daily ride. No track days but I drive it like it was meant to I am unsure that the pro kit is too soft but also if the Sportline kit is too low. I have 37,5cm from hub to fender in the front and 35 cm in the back. That translates into about 5,5cm from top tire to fender in the front and about 4 cm in the back. Does anyone have expirience with the Sportline B12? I have lowered two previous cars with Eibach pro springs but never got the mm lower that was listed.
2020 G20 330e
2015 F31 LCI 320d ed 2004 E46 LCI 320d Touring 1996 E36 316i Bavaria Compact |
