10-10-2020, 07:53 PM | #133 |
Rep 210
Just joining this thread, setup listed below with a corner balance and the car is solid.
KW Clubsport coilovers Racing line strut tower brace F80 LCAs Turner monoball thrust arms Afe sway bars Delrin rear subframe bushings GSP Rear Trailing arms |
Insane435476.50 |
10-11-2020, 10:01 AM | #134 |
Rep 194
Do you track this car? Or is this your street setup? For comparison, how's it feel relative to an M3?
10-11-2020, 10:37 AM | #135 | |
Rep 210
2014 335i M Sport: bootmod3 Stg 2 E30 Custom, AA CP, CSF FMIC, GFB DV , VRSF catless DP, aFe stage 2 intake, KW Clubsport coilovers, MP LSD, aFe sway bars, F80 LCAs, monoball thrust arms, Delrin rear subframe bushings, xHP Stage 3.
IG: German_car_connection |
pkiledj46.00 |
10-11-2020, 10:46 AM | #136 |
Rep 210
I also daily it still at this point, it's not too bad. I drive it to/from Sebring fro track days which is the closest track to me.
04-13-2021, 04:02 AM | #137 |
Rep 183
For anyone attempting to install the M140i/440i LCI Msport front anti roll bar (Part Number - 6792120) on the B48 F30 LCI, you will need to drop the coolant hose to a lower level as shown in the Dinan installation guide.
pkiledj46.00 |
05-15-2021, 04:24 AM | #138 | |
Rep 1,348
2k15 335i Msport xdrive 6spd
05-22-2021, 02:42 AM | #139 |
Rep 108
So, did somebody install the M135 front sway bar to his 335 x-drive?
Lancelot did, but said first it's too soft, then corrected saying it's good, finally switching to Eibach. Not sure if he had 6-cyl. though... |
05-22-2021, 06:42 AM | #140 | |
Rep 8,498
Just my opinion, but I'm very happy with the Eibach units.
05-22-2021, 07:18 AM | #141 | |
Rep 1,291
Not front x drive bar, only rear from xdrive m135i (on 6 cyl f30) It was OK with stock front bar, but cannot comment for xdrive car though. Sway bars are a headache on those cars, especially considering how difficult they are to change. I switched to an M550i now with active roll bars, much better
2017 M550i | Sophistograu
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i |
05-22-2021, 07:19 AM | #142 | ||
Rep 1,291
JMNC0.00 |
06-06-2021, 02:40 AM | #143 | |||
Rep 5
I have been reading this post in great interest. I have upgraded my suspension to Eibach Prokit springs & Bilstein B8 in my puny 318i It has managed to reduce the float feel but want to improve the cornering . After reading this post, I am incline towards Eibach's Sway bar. The next question is will i need to change to adjustable end links as well ? Thank you . |
06-06-2021, 04:08 AM | #144 | |
gds
Rep 25
https://f30.bimmerpost.com/forums/sh....php?t=1709419 By the way how is the ride quality and handling with the b8s? |
06-06-2021, 09:24 AM | #145 | ||
Rep 5
Honestly comfortable but bouncy on undulation road with this combo, not harsh. Less firmer than some of cars I have driven. Did u change your end link ? Thanks a |
06-07-2021, 03:45 AM | #146 |
gds
Rep 25
06-07-2021, 04:00 AM | #147 | |
Rep 5
Ic. If just shocks and sway bar, the ride feel maybe different from mine. U intend to use back OE springs ? I think with standard OE springs, B6 is used. |
06-07-2021, 05:29 AM | #148 |
gds
Rep 25
I am on coilovers right now. I will return to m sport springs and Koni sport or bilstein b8 (these are the recomented for msprt suspension ),that s why i m asking about the ride quality of the b8s . My imperession is that the b8s are stiff for daily driving (i will not track the car)
06-07-2021, 09:57 AM | #149 | |
Rep 5
06-07-2021, 12:04 PM | #150 |
gds
Rep 25
Ohlins Road n Track..
10-01-2021, 10:23 AM | #151 |
Rep 275
As someone with an F36 440i with m adaptive suspension, is there an "easy" upgrade that will dramatically reduce body roll? are the anti roll bars with considering in isolation?
Previous: 2002 E46 330i M-Sport (m54b30 LCI), 2007 E92 335D M-Sport Coupe (m57), 2003 z4 3.0i (m54b30), 2010 E92 325D M-Sport Coupe (n57 LCI), 2019 F36 430i M-Sport Pro Gran Coupe, 2018 F36 440i M-Sport Pro Gran Coupe MPPSK
Current: MY2021 M550i, Aventurin Red, Ivory Nappa, Comfort Pack, Tech+ |
10-01-2021, 11:38 AM | #152 | |
Rep 1,291
So you have to drop them to access the roll bars.
10-01-2021, 11:48 AM | #153 |
Rep 275
Thanks! What are the best options, and how much difference would they make?
10-01-2021, 12:51 PM | #154 |
Rep 1,291
I think the best is the eibach set, some prefer the h&r but to me they don't have enough compliance for road use.
