06-09-2018, 05:03 PM | #1 |
Rep 638
Just ordered a pair of dinan sways. Anyone know what the best setting is? The instructions say full oversteer for 335/340 which is not what I'm looking for. I want it to understeer and stay close to stock but significantly stiffer. Front full understeer and back middle?
06-11-2018, 08:32 AM | #2 | |
Rep 150
If you haven't already, I would recommend calling Dinan and see what they say.
2020 M340i xDrive
Dravit Grey Metallic Modifications July 23rd - Dyno Tune |
06-18-2018, 04:16 PM | #3 |
Rep 320
how are you finding it so far?
I only installed the rear bar and im running it in the first hole which is the stiffest setting. it might be a bit much for street but for autos its where I need to be. turn in is significant sharper and the front tires bit alot more through transitions. the rear feels planted. it was oversteering a bit but I took some air out of the rear tires and that seem to help it during my autox runs... the front still rolls a bit so ill be putting in the front bar this week and we'll see what happens |
07-03-2018, 03:46 PM | #4 |
Rep 4,109
Drives: BMW M3
I don't think a stiff rear sway bar is a good idea, especially with an open diff. On a RWD car there needs to be some independence in the rear suspension movement (the left wheel movement not affecting the right wheel movement and vice versa) so the rear tires stay in contact with the ground. Look under BMW CCA race cars, etc - very thin rear sways, if they even run one.
The front, on the other hand, you can go very stiff. The front of the car doesn't need to roll in order to transfer weight. You accomplish weight transfer just by turning the steering wheel, that is what makes the car turn, not body roll. So reduce roll up front and allow some roll in the rear. Charles
2024 BMW M3 Sedan Frozen Pure Grey II/Fjord Blue, 6MT
Past: 2021 Z4 M40i Frozen Grey II/Black Alcantara | 2017 F30 340i Mineral Gray/Coral Red, 6MT | 2011 E92 335i Le Mans Blue/Black, 6MT |
07-24-2018, 12:55 PM | #5 | |
Rep 320
07-25-2018, 02:42 PM | #6 |
Rep 891
While I have not changed the sway bars in my car, even with all of my mods the car still has progressive understeer at the limit while very neutral to that point. I wouldn't want my front end more stiff than it is because I am already contesting understeer on corner exit. I'm going to increase my rear rebound setting for my next track day and see if that makes a pronounced difference. Beyond that I would consider a RSB, but think that a proper LSD is the better option for me since I'd rather have throttle controlled oversteer rather than it be inherent in the chassis.
Just be conservative while stiffening your car, take it one step at a time to figure out what you're happy with. Going full stiff can make normal driving feel good but can be like walking on a cliff edge at the limit. The best way to reduce understeer, particularly in our cars, is to increase front negative camber and tire size.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i Last edited by MacklinUSOB; 07-25-2018 at 03:04 PM.. |
Lancelot567.50 |
07-28-2018, 10:59 PM | #7 |
Rep 65
Drives: 2017 340ix M Perf, 2019 M2 Cmp
I have and 340iX with front and back Dinan sways set up at the stiffest level, car will oversteer somewhat but when pushed real hard. Its actually pretty neutral. I would expect an RWD to break loose a little faster but would not be worried to much about it. Mind you my garage queen is an S2000 with 10 year old RE11 that will snap over-steer all day so I find the 340 pretty tame in that regard .
To be completely transparent I also have Dinan's springs and I drive with BMW Adaptive Dampers in Sport + which favors oversteer.
Dan
07-28-2018, 11:54 PM | #8 | |
Rep 1,291
Stiff rear even with LSD isn't desirable, in case of lifting inside wheel even if wheel spin is controlled you obviously lose contact and therefore stability, and ability to put down power. Stiff front allows for sharp controlled turn in. Then with LSD you get to control oversteer with throttle.
2017 M550i | Sophistograu
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i |
07-30-2018, 10:23 AM | #9 | |
Rep 320
03-23-2020, 12:41 AM | #11 |
Rep 102
Hey guys have a 340i RWD with m sport and adaptive suspension got the dinan shockware
Are the dinan sways any good and what setting would you guys have in the rear so it doesn't completely take away the independent suspension. Just want the body roll to go down a bit and have more feel on the corners. Don't want it to be a track car by any means |
03-23-2020, 10:16 AM | #12 |
Rep 3,539
The Dinan sway bars are good IMO, especially if you go to higher spring rates since they're not too stiff. I'd start on full soft for both front and rear.
Since you're RWD, you also have a lot of options for front and rear bars. You could pair another different front bar with the Dinan rear if you wanted. I have a brand new Dinan rear sway bar for sale here. Where in CA are you?
04-01-2020, 12:57 PM | #13 |
Rep 638
Hey there,
I had a good experience with them on the 340i when they were set to middle stiffness on both F & R. I tried to do softer out back versus front and it created an awkward imbalance. Then, I went full stiff F & R but that took away too much independence and created a very skittish ride. Stick to medium all around if you get the Dinan springs as well, otherwise go full soft. |
04-17-2020, 04:16 AM | #14 | |
Rep 102
Got it done for $800 at my mechanic (I know pretty crazy) Right now it's not really feeling too planted... the turn ins are a bit better but still the car seems to flop around a bit before straightening out the wheel... I've got the front and back sways set in the middle setting... anybody have any suggestions on how I should adjust it or what I should do. (I don't want lowering springs because I already have a front splitter and it'll be impossible to go up my driveway. Plus had dinan Springs on my older 340i non M it sucked.) but if anybody sees this please help! |
04-17-2020, 02:31 PM | #15 | |
Rep 320
04-17-2020, 02:42 PM | #16 | ||
Rep 102
04-17-2020, 02:58 PM | #17 | |
Rep 320
i tried middle in the front and stiffest in the rear and it felt "out of sync". the front had more grip but rolled alot more and since the rear had less compliance it wanted to swing around. if you only stiffen the front and leave the rear in the middle, the car will have a tendency to understeer which you don't want. |
