05-16-2024, 11:39 PM | #1 |
Rep 17
I just purchased a B58 Axle Back of a 2018 340i for $500 CAD.
Please see attached image to see difference for the exhaust B58 vs N55 I’m looking to install it on my N55 435i 2016. I noticed the B58 MPE exhaust has two valves but my N55 has only one plug for the valve on the drivers side. I’ll take it to a shop tmrw to have it welded on, thoughts? Will it work or will the flaps remain close? Thanks! |
05-17-2024, 07:50 AM | #4 |
Rep 557
Drives: 2019 440i XDrive GC
Just a heads up, thats the B58 MPPSK which is different than the MPE for B58. MPPSK is the full catback with dual valves. MPE is just the muffler with no valves. 2 veryy different things.
If you're doing the full catback, look to see if aftermarket catbacks are the same for n55 and b58 f3x cars. If they are, then the MPPSK will likely fit. Like eff32fl mentioned, you'll need a second valve controller and the Y cable to split your single valve wiring harness into 2, one for each side.
Current: 2019 440i xDrive Gran Coupe - Alpine White, Coral Red Dakota Leather, 8AT, MSport, THP, BM3; 2015 X5 35i xDrive - Mineral White Metallic, Mocha Dakota Leather; Previous: 2015 Subaru WRX - World Rally Blue, Premium, FBO+Tune
hamiddal4.50 |
05-17-2024, 08:23 AM | #5 | |
Rep 17
What are valve controllers? I have two valves theone that are on the exhaust already, I just need to plug them in using the Y cable. See attached on the one I plan on ordering from AliExpress |
05-17-2024, 08:47 AM | #8 |
Rep 17
freakystyly3472.50 |
05-17-2024, 08:51 AM | #9 |
Rep 1,961
I'm not sure if there's some confusion in your original post. You purchased a B58 exhaust was it, stock, MPPSK or MPE? There are three types. The MPE has 0 valves, the stock has 1 valve and the MPPSK has two valves (and comes with a tune).
The yellow one you have highlighted with two valves is the MPPSK. The one under it is the MPE with 0 valves. Either way, good deal for $500 CAD and I'm a bit jealous lol. The N55 midpipe doesn't line up perfectly with the muffler and would need a little bit of work to fit. Hanger locations are a bit off, angle of piping, etc. It isn't a straight swap. |
05-17-2024, 08:56 AM | #10 | |
Rep 17
05-17-2024, 10:43 AM | #11 |
Rep 16
I believe you just need the Y cable to connect to the second valve. Here's the official installation instruction.
https://rparts-sites.s3.amazonaws.co...LL%20INSTR.pdf |
