05-20-2024, 02:02 AM | #1 |
Rep 121
MHD N55 PWG Stage 1 Possible Boost leak?
Hi guys,
I just installed MHD stage 1 on my N55 PWG but it seems it doesn't meet the boost target. Is this a possible boost leak? Everything looks alright, except the STFT and boost under target which leads me to believe that there is a boost leak but my question is, shouldn't WGDC be 100% because it should be closed to meet the boost when a boost leak occurs or it's not a rule of thumb? Attached the log. https://datazap.me/u/minulache/stage...og=0&data=4-16 Many thanks for the help! |
05-20-2024, 01:13 PM | #2 |
Rep 7,733
That amount of deviation does seem like a leak, yes.
WGDC doesnt read on a 0-100% scale for PWG like you would think. Even when you are "maxing" the turbo it wont read 100%. EWG is a bit different and does read more intuitively on a 0-100% scale but even for EWG it wont always shoot to 100% if you have a leak |
minulache52.00 |
05-22-2024, 11:56 AM | #3 |
Rep 121
Tried today to smoke test but I am smoking from the inlet pipe on the turbo, so that is not the cause of the boost leak...I cannot seem to get it to pressurize so I could actually see from where it's coming from. Any ideas from where to smoke test the N55?
View post on imgur.com View post on imgur.com |
05-22-2024, 12:40 PM | #4 |
Rep 7,733
I describe how to pressure test in this thread, there are various places you need to cap off when you try to pressurize from the inlet foward.
https://f30.bimmerpost.com/forums/sh....php?t=1621695 Also smoke alone might not work, you need pressure. |
minulache52.00 |
05-30-2024, 03:36 PM | #7 |
Rep 121
Update time. I replaced all the gaskets, no more leaks detected after the turbo but still same result on Stg 1: https://datazap.me/u/minulache/log-1...og=0&data=4-16
I also put Stage 1+ for curiosity on the car, and the boost seems a bit better, but still under target and negative STFT:https://datazap.me/u/minulache/log-1-2nd Any other ideas...? |
05-31-2024, 04:48 AM | #9 |
Rep 121
I would say that based on the deviation that I see at other people this is normal for PWG cars. But the STFT is not really, I only saw on a few cars. I also put the logs into Virtual Dyno and the result is not that good.
Only 10whp stock vs stage 1+... View post on imgur.com |
06-03-2024, 07:53 PM | #10 | |
Rep 7,733
https://f30.bimmerpost.com/forums/sh....php?t=1710794 |
minulache52.00 |
06-04-2024, 08:13 AM | #11 |
Rep 121
Thank you very much. Today I changed the gaskets from the intercooler and from the turbo outlet to intercooler and now it's holding boost as it should for a PWG, so problem solved
06-09-2024, 01:44 PM | #12 |
Rep 121
So, I noticed that now my boost is very good after all the changes BUT my WGDC hits 100%... any idea what I should look for? I think it's clear that there is no boost leak given the boost pressure now. Maybe the pressure converter or boost solenoid?
https://datazap.me/u/minulache/0906-...og=0&data=4-17 |
06-11-2024, 07:01 AM | #14 |
Rep 121
Hi Jeremy, looked before also posting here and it is not normal. My next option is to try with a new pressure converter/boost solenoid. Other than that, I am a bit lost, not gonna lie.
Checked also the vacuum lines and they are all good. |
