10-12-2020, 03:46 PM | #1 |
Rep 3
Drag tire setup
Hey guys, new to the forum but not to the car or racing.
Currently I am running a MHD stage 2 e30 tune, XHP Stage 3, Intake, Catless Downpipe and a 3" exhaust. Currently I have been able to consistently hit 7.5's in the 1/8th but I have had to turn down my launch control torque so I am not giving a smoke show. I am currently on little 255/35/19's and pulling 1.8 60's. My next purchase is going to be a dedicated drag wheel and tire set up because a stage 2 HPFP and a GC is in the works. My question is a 2 part one: A. How do you disable the low tire warning that only allows you to be in comfort mode? B. I am going to run 17's so should I run a 275/40/17 or a 295? Any additional advice would be greatly appreciated. |
10-13-2020, 01:20 AM | #3 |
2JZ-GTE
2959
Rep 3,948
I've heard you can code it out but have not seen the process. I use esys. You could re-calibrate the sensors at a lower psi or just have them removed when you have the tires changed. |
10-20-2020, 09:31 AM | #4 |
Cheapskate
4442
Rep 4,992
You won't fit a 295 and probably won't find a properly wide 17 for it. a 17x9 with 275 is your best bet but many people run 255 and hook well. It's more about the compound than the width.
10-20-2020, 02:41 PM | #5 |
Rep 684
Drives: Your mom crazy
Garage List 2020 BMW X3M CURRENT [0.00]
2016 BMW 340i BEAST [0.00] 2011 BMW 335i RIP [0.00] 2003 BMW 330i SOLD [0.00] |
Someone on the B58 Enthusiasts Facebook group made a post about working with a coder that removed the low tire pressure error. Search the group posts or post an ISO message asking who it was.
10-20-2020, 08:05 PM | #6 |
Rep 4,842
Mine doesn't have the physical TPMS, just the rotational check. I'd assume if you code out TPMS to the "ghetto" version that I have, your problem would go away.
11-20-2020, 03:46 PM | #7 |
Rep 3
11-21-2020, 01:13 AM | #8 | |
Built Motor F30 340i
401
Rep 257
Supr3me551.00 alpinweiss34088.00 |
11-21-2020, 10:31 AM | #9 | |
Rep 684
2020 X3M
MG Flasher; Wedge Performance E50 tune MSS Urban; Rohana RFX11 |
SC_B5X401.00 |
06-25-2022, 03:50 PM | #10 |
Rep 14
Drives: Bmw 340i
Hey what did you end up doing for your tire setup
06-26-2022, 03:01 AM | #11 |
Rep 1,010
If you will buy a dedicated set go for the smallest diameter possible for faster acceleration.
2018 340i 8AT RWD - M Sport - Catless MPPSK - Stock Turbo - Stock HPFP
-------- Tunes: Self Made Tunes - MHD ------ Fuel: 92RON/87OCT -------- |
06-27-2022, 02:54 PM | #13 |
Rep 99
This is 275/40/R18 on Apex profile 3. Lowered on BC BR coils, I needed to have the fenders rolled because I was rubbing.
2016 340i xDrive | Pure 800 | Dorch S2 | XHP S3 | bm3 | F80 Paul 94 + Meth Custom Tune | CTS Intake | VRSF Catless DP | BMS Elite CP | Snow Perf VC50 + Dual CM7 CPI | BC Racing BR Coilovers | Apec ARC-8 + Hankook Ventus RS4 |
F30Pat2.00 |
06-27-2022, 04:57 PM | #14 | |
Novice
297
Rep 685
currently rn the car came with the classic 400m wheels from factory and for awhile I do not plan to get aftermarket rims. I was told I could run 265/35/18s in the rear but I want to know the maximum meatiest tires I can run for the rears and fronts without losing the performance benefits. currently rn I am running 255/40/18s in the back I believe and 225s in the front. michelin pilot super sports. |
08-01-2022, 02:25 PM | #15 | |
Rep 18
