10-17-2020, 09:13 AM | #1 |
Rep 91
2015 435 - Castrol Edge 0w-40 vs Motomaster OE Plus
Going to change my oil before storing my car for winter. I only put 2500 km on it this summer.
About 2100 of those kilometres were with a BM3 stage 1 91 tune. I've been doing a lot of research on oils and decided to go with Castrol Edge 0w-40. Canadian Tire only had 1 L jugs going for $13.99 each. So 7 jugs was $110. However the guy showed me Motomaster OEPlus 0w-40 on sale for $27.50/5L. So I got two of those also. Both oils have same requirements/approvals for MB and VW, except the Motomaster doesn't have the Ford or Porsche A40 cert. Which brand should I return to the store? |
10-17-2020, 11:01 AM | #2 |
Rep 1,597
I prefer Castrol. If you will change this oil out after winter or under 5000 miles, you could use Motomaster and look for some cheaper sources for Castrol 0w-40 Euro which for 1L bottles is expensive. Look for gallon jugs.
10-17-2020, 11:06 AM | #3 | ||
Rep 91
Still $100 cheaper than the dealership. |
10-17-2020, 11:44 AM | #5 |
Rep 91
10-17-2020, 01:29 PM | #6 |
Rep 16,079
Motomaster is a CT house brand. Obviously CT doesn't own a refinery. They get their oil from various sources, including Shell and Exxon. With a bit of effort one can find out where any of their oils from.
10-17-2020, 01:54 PM | #7 |
Rep 1,597
If its rated for BMW, has the proper detergents, and it is synthetic, there should be minor difference between oils up to 4-5000 miles. I would use the Motomaster for a winter oil and if you are curious about continuing with Motomaster, you could send a sample of it into Blackstone for analysis. I have gotten good analysis results from Castrol 0w-40 so I stay with it and it is cheap at Walmart.
10-19-2020, 10:23 AM | #8 | |
Rep 91
I still want to drive my car for a little bit longer before putting it away for storage (about 70km/40mi total) This should be fine right? |
10-20-2020, 10:14 AM | #9 |
Rep 1,597
Theres no problem with fresh oil just make sure you drive it long enough to burn off any moisture. There would have been not a problem with the Motomaster as a winter storage oil either.
