04-14-2021, 05:26 AM | #23 |
Rep 15,858
My understanding, it's also the battery State of Health (SoH) that is being monitored and charging strategy modified as the battery ages.
A new battery requires the registration to 'reset' the battery management. |
04-14-2021, 08:25 AM | #24 | |
Rep 709
I recently removed the original battery as it wasn’t charging enough for the stop/start to work. A battery load test prior to repair showed it to be in bad health. 4 days later on the recovery cycle on a Noco G15000 and it now shows in good health. If there was such a program to monitor the health and create a charging strategy on the car then it failed miserably. Most likely as I stated previously to maintain a charge level on the battery with minimal engagement of the alternator for fuel economy |
04-15-2021, 12:26 PM | #25 | |
Rep 2,069
A new battery, regardless of "like for like" should be registered in the car so that battery management is optimised. It's not just a BMW thing either. Same applies to other manufacturers whose systems use intelligent battery management.
/// BM3 + M-Power ///
04-15-2021, 03:06 PM | #26 | ||
Rep 709
This is from another forum and describes how the alternator charges the battery. I believe it was written by HighlandPete Quote:
If the intelligent battery management worked to protect and prolong the life of the battery then why is the charging system damaging to a battery? Secondly, a battery that wouldn’t allow the stop/start to work, even after a charge and a long drive but after the same battery was recovered on an intelligent battery charger it now works fine? Both charging and monitoring systems are designed to increase fuel economy and decrease emissions as a result. Both of which would save more money in fuel and taxes than the cost of a battery over its lifetime, even if shortened under the charging system. |
04-15-2021, 03:40 PM | #27 |
Rep 1,437
tbh the biggest battery killer has been the pandemic.
The number of friend/relatives that have had to replace batteries is significant. My friend's Merc MPEV battery died due to lack of use costing over a £1000 to sort. my 335D has had no problems over the last 100k miles and 6 years, but the last year of use means it stays connected to my optimate 6 to ensure the battery is conditioned/desulphated properly. I've just ordered a optimate solar (duo solar if you have a lithium battery) so i can leave it anywhere, given I'm unlikely to snap back to 15k pa. may as well buy a charging point and a proper EV ... |
04-15-2021, 03:44 PM | #28 |
Rep 107
I put my car on charge last week and charged it full. After 3 long journeys start stop wouldn't work. Today I put the charger back on, but this time on repair mode, after 4 hours repair finished, then I put it onto normal charge again for 6 hours. went out for a drive and start stop works again!! Fixed!
2016 320d M Sport LCI
04-15-2021, 04:06 PM | #29 |
Rep 1,437
Yep standard chargers or tickle chargers don't really work with agm batteries.
I managed to cause my agm race battery to bow out by leaving it connected to 300ma trickle charger over winter man toys rule ... |
04-15-2021, 05:08 PM | #30 | |||
Rep 2,069
04-15-2021, 05:22 PM | #31 |
Rep 15,858
I think there is a bit of a crossed conversation going on here.
How a battery deteriorates and its longevity under energy management, is a different point than a new 'unregistered' battery and how energy management may not give the optimum charging and longest life cycle. It's known a new 'unregistered' battery can have a short life, whereas the original battery lasted a good few years longer. The difference... not following the guidance to reset the system to a new battery. |
04-16-2021, 01:44 AM | #32 |
Rep 969
BMW refused to replace a battery on my old E92 under AUC warranty as they kept saying it was charging and fine even though after 2 weeks of use stop/start would fail along with the clock, heated rear window etc.
They even tried to register it as a new battery to get the car to charge it more, they didn't like the fact I knew this as Carly shows a history of battery registration and it shows they must of suspected a fault. |
04-16-2021, 02:59 AM | #33 | |
Rep 709
I asked you two questions, neither of which you have answered so assume you’re unable to |
04-16-2021, 03:49 AM | #34 |
Rep 542
Summary:
If you fail to register a new battery (eg. capacity like for like), the system will only charge the new one to a reduced capacity (<80%) because of the IBS age degradation charge curve. Depending on the age of the original battery, the new one may never be charged above 50% capacity. (I don't know what the curve is). Sulphation degradation will be very high. Conclusion: To prolong the life of a new 90AHr battery, register it as a 110AHr device. The system will 'over-charge' it, but in reality, instead of that being normally 80% charged, it will be 97% charged. That will reduce the long term sulphation and hence, prolong the life of the battery.
335d xDrive
04-16-2021, 04:07 AM | #35 | |
Rep 709
The downside is the battery never becomes fully charged and any spare capacity is open to sulphation. The longer this happens the harder it is to remove these crystals without damaging the battery further. The only argument I’ve heard so far is the battery needs to be registered so the intelligent battery management knows it is new. The management will then change the way the battery is charged as it ages. The problem is now you have had years of the battery kept to SOC of around 80%. The voltage still reads good but the amp hours are reduced and can’t be recovered without some kind of recovery. The recovery is from high voltage charging to flake the crystals off the plates where it can then dissolve back into the electrolyte. Continuous high voltage charging damages the plates though as well as creating heat that evaporates the electrolyte so it needs to be done in short pulses. The alternator can produce the higher voltage as it is normally reduced the regulator and having the charge pulsed is easy enough to do too. This doesn’t happen though as myself and many others have recovered batteries that the car is saying isn’t serviceable and prevents stop/start from working. After recovery they work fine and as it’s the same battery surely the system is still treating it as an old battery therefore supposedly changing the charge program to suit, when in fact the recovery has it performing with the capacity of a much younger battery. My argument is the intelligent battery management system isn’t about looking after the health of the battery otherwise you wouldn’t be able to recover one that the car says requires charging. I think the system is to maintain the ability to start the car as the battery becomes more damaged by turning other high demand systems off. |
04-16-2021, 06:33 AM | #36 | |
Rep 15,858
Also depends how we are looking at the function of battery management. If it is to work as an economy 'mechanism', it way well be doing a good job, the best it can under the design brief and application. I agree it may not be the best for a battery, but what is the 'reduced' life cycle are we talking about? A couple or years less, if so, compared to what? Some AGM batteries in the current applications are lasting longer than lead acid batteries in conventional charging systems. What you have stated about battery degradation, (which I don't disagree with), also emphasises to me how important registering is, to get a more 'aggressive' (if it's the right term) charging regime for a new battery, extending its useful life, compared to not registering it. |
04-16-2021, 08:01 AM | #37 | |
Rep 709
Battery management and any aggressive charging it is supposed to do as the battery ages is of minimal benefit as it doesn’t work. It allows the sulfation to occur and the long periods of time required to reverse this at a high charge rate aren’t available in a car even on continuous charge if the energy management allowed it. It’s not just AGM batteries that will suffer this problem but any lead acid ones. I don’t think changing the energy management to suit the battery is the-way forward, it is just a consequence of running the engine more efficiently. Maybe the answer is in Lithium batteries but these have their own issues as well let alone the additional cost. |
04-16-2021, 12:08 PM | #38 | |
Rep 19
04-16-2021, 01:18 PM | #39 | |
Rep 709
If you have a motorbike and need to charge that too then go for the 5 amp versions of either as 10 amps is a bit high for little batteries. |
04-16-2021, 03:19 PM | #40 | ||
Rep 2,069
If a new battery doesn't or shouldn't need to get registered with the car, manufacturers wouldn't tell you to do so. It's absolutely nothing to do with how you maintain an existing battery... which will of course have been registered correctly. You are informing people that a new battery doesn't need registering. Which is wrong, and the point of my original reply.
04-16-2021, 03:22 PM | #41 | |
Rep 107
I got this one, cheap and does the job.
04-16-2021, 03:49 PM | #42 | |
Rep 709
BMW also tell me my gearbox is sealed for life, I guess that’s gospel too |
04-16-2021, 04:16 PM | #43 | ||
Rep 2,069
The manufacturer states (as I quoted) that a new battery SHOULD be registered. You're telling people it doesn't matter. Reasons for registering have been covered. Hopefully anyone having a new battery, having read this thread, will side with the advice of BMW & have it registered.
04-16-2021, 04:36 PM | #44 | |
Rep 1,060
