04-15-2021, 08:15 AM | #1 |
Rep 8
F30 LCI Rear Indicator not working
Hey guys,
So noticed left side boot indicator light not working. Thinking it was a short (from an LED?) took everything apart and found nothing. 6 pin connector looks good no burn marks. The housing where the connector fits into, the pins looks fine, all the same. All other LED parts of the lights work just the indicator doesn't. Did find a dead bug inside if you look at the pictures. Surely this didn't cause any of the indicator LEDs to blow as such? Disconnected the right side boot light and connected it to the left side 6 pin. Turned it on and right side indicator and lights work fine. Tried the left faulty boot light and connected to right 6 pin, indicator still not working so surely not a wiring issue. Can't open the backside of the light to see the circuitry and all but from the outside it looks all fine to me. So quite stumped. Would I need to buy a whole new part (63217456521)? 170 quid new, probably pick one up second hand for 60 ish but before I do that does anyone else care to help? Cheers image hosting |
04-15-2021, 12:06 PM | #2 |
Rep 2,068
Looks like the signal LED module has died, or the LED driver.
If you have no warranty then it's going to cost unfortunately. As it's toast, Even if you have a go gaining entry inside the unit, it's still going to have to be tested & faulty bit either fixed or replaced... probably of similar cost to sourcing an entire second hand lamp. I'd just look to replace it tbh. You could always try BMW for good will... as these are meant to last the life of the car.
/// BM3 + M-Power ///
lakm1.50 |
04-16-2021, 06:54 AM | #3 |
Rep 8
Thanks T5
Yeh I'm out of warranty and didn't opt for the extended about a few months back. Will try my local dealer see if they are able to offer a new one out of goodwill however they may tell me to Foxtrot Oscar and order a new one at their parts department! |
t5pilot974.50 |
04-18-2021, 07:28 AM | #4 |
Beemer Heaven
462
Rep 2,941
Drives: BMW M4 Competition
Garage List 2018 BMW F82 M4 Comp [0.00]
2017 BMW F30 330d M ... [0.00] 2014 BMW F30 330d M ... [0.00] 2009 BMW E90 330d M ... [0.00] 2006 BMW E90 330d M ... [0.00] 2002 BMW E46 325i S ... [0.00] |
The extended warranty would of cost a lot more than to replace that lamp unit so you’re still better off I’d say.
Scott
2018 BMW M4 Competition 2019 Mini Countryman Cooper S : 2008 Mini Cooper |
lakm1.50 |
