02-19-2019, 08:02 PM | #1 |
Yiolli
26
Rep 119
Apologies if this post isn't in the right spot - I'm still new to this forum and this is my first post
I'm hearing a weird buzzing/cricket sound at very low RPMs in my 2015 F32. It happens mostly while accelerating but it's also sometimes there while maintaining a constant speed (mainly between 0-30 MPH) My best description of the sound is that it's similar to an older computer when it's working very hard...not the fan noise of a computer, but that weird buzzing/loading sound Has anybody else experienced this? |
02-19-2019, 08:20 PM | #2 | |
Rep 799
A permanent Fix for the 335i/435i 2500 RPM Rattle/Buzzing/Whirring Noise? https://f30.bimmerpost.com/forums/sh...d.php?t=949816
Yiolli25.50 |
02-19-2019, 09:45 PM | #4 |
Yiolli
26
Rep 119
Definitely somewhere in the engine bay/inside dash. Doesn't seem to be within the cabin. And definitely seems to be connected with the accelerator (I can tap the accelerator and then release and the sound is clearly correlated)
02-19-2019, 09:46 PM | #5 | ||
Yiolli
26
Rep 119
02-19-2019, 10:34 PM | #7 | |
Yiolli
26
Rep 119
Here's a short clip of me reving the engine. At times its very subtle but turn sound up and listen closely - most noticeable around 28 seconds into the video |
02-21-2019, 01:04 PM | #8 |
Rep 552
I can hear it at 28 seconds. Is that when the car is at a standstill?
I have a similar noise that's constant when moving sounding like it's coming from the passenger side but its very faint. Sort of chirpy high frequency whine noise. I remember when I was looking for a rattle noise when the car is stopped and in drive. I took the engine cover off and there was a metallic rattle noise coming from the metal pipes at the top of the engine. But there wasn't anything loose. Haven't been able to diagnose it yet. |
02-24-2019, 05:38 PM | #9 | |
Yiolli
26
Rep 119
I can't seem to replicate it for the dealer and they "can't do anything" with a video. I'm at a loss for how to treat it |
02-24-2019, 05:56 PM | #10 | |
Rep 552
First I thought it was the brakes rubbing slightly or the wheel bearing. But been driving it for a while and it's not got any worse. First I think you need to find out where the source of the noise is coming from. Get someone to rev the car and see if you can locate where the noise is coming from. Your noise is affected when you rev the engine so sounds like something is loose. Check the engine bay area to see if anything loose. |
02-24-2019, 05:59 PM | #11 | ||
Yiolli
26
Rep 119
02-24-2019, 06:10 PM | #12 | |
Rep 552
There was a noise similar to yours coming from the pipes when the engine is just idling. It was quite loud. The engine cover has a thick foam to dampen this area. Might be worth taking the cover off to and checking from this area |
02-24-2019, 06:15 PM | #13 | ||
Yiolli
26
Rep 119
02-24-2019, 06:22 PM | #14 | |
Rep 552
My previous car has a high speed vibration/drone issue. Tried everything, replacing drive shaft, diff. Never solved it. Sold the car in the end. |
02-24-2019, 06:27 PM | #15 | ||
Yiolli
26
Rep 119
02-24-2019, 06:33 PM | #16 |
Rep 552
02-24-2019, 06:37 PM | #17 | |
Yiolli
26
Rep 119
Rattles or no rattles, they're a delight to drive! |
02-25-2019, 02:45 AM | #18 | ||||
Rep 552
The pipes I was talking about are for the director injectors on top of the engine. Is this similar to yours? Last edited by kingmonkey8; 02-25-2019 at 04:55 AM.. |
03-06-2019, 07:59 PM | #19 | |||||
Yiolli
26
Rep 119
You're saying this is related to the fuel quality? Is there any fix ? |
03-07-2019, 04:10 AM | #20 | |
Rep 552
It seems that cars with direct fuel injection have this inherent problem across manufacturers. If you google 'high pressure fuel pump noise' then you will find videos with the same noise. The noise is the same as yours so I would guess it's something related to the high pressure fuel pump or fuel lines. Being affected by revs also makes sense as the fuel pump works when you rev the engine. The video say's his problem is affected by the fuel. So you could try a different octane fuel to see if that makes any difference. Or you could maybe try replacing the high pressure fuel pump. |
Yiolli25.50 |
03-07-2019, 07:19 AM | #21 | ||
Yiolli
26
Rep 119
