07-19-2019, 12:30 AM | #1 |
Rep 42
ABS/DSC Module Coding
Hey guys so according to indy mechanic I had check my car. He said that my abs/dsc module may be faulty. The problem I am having is it seems like it activates my rear brakes without any brake pressure. So as I am driving the rears start to stick or randomly brake. Upon disconnecting the whole module the problem goes away. Ended up pulling the module fuse to remedy the situation so my vehicle is still drivable.
Now I ordered a whole abs/dsc pump and module off ebay from another 335 but without M Sport brakes but further research shows I may need to code the new module to my car. So my question is does anyone have any guidance or help regarding how to code a new module to the vehicle? |
07-19-2019, 08:20 PM | #3 |
Rep 42
07-20-2019, 12:42 PM | #4 |
Rep 2,302
With Bimmercode not possible.
With E-Sys: Connect the car. Go to Coding. Read VO and activate VO. On the right side "Read Ecu". The new DSC ecu should now appear in the SVT tree. Mark the DSC and on the right side "detect caf for swe". Choose the CAFD with the highest numbers and OK. Hit the button "Code". That's all and should work. |
12-22-2020, 08:42 PM | #5 | |
Rep 27
Hi, Murd0x, I got the exact same problem now and wonder which fuse to pull to disable the module to get the vehicle drivable. thanks a lot!!!
just need to move the car to a close place Quote:
