08-18-2017, 01:56 PM | #1 |
Rep 2
435i F32 Instrument Cluster Display Issue
Half of my instrument cluster LCD display is blank most of the time. I performed the cluster reset test hoping that it would fix my issue but haven't had any luck. Before going to BMW I wanted to see if there were any suggestions out there.
https://ibb.co/mLS5Rk https://ibb.co/ighN6k Last edited by Gm_809; 08-18-2017 at 02:02 PM.. |
08-18-2017, 02:33 PM | #2 | |
No 55mph
1621
Rep 8,476
Have never seen that, did you retrofit a different cluster or is that the factory supplied one? Have you done any coding for the dash module prior to it looking like this?
08-18-2017, 02:41 PM | #3 |
Rep 2
This is OEM display from what I know. I purchased used so no telling what the original owner has done No coding has been done from my end.
435, f32, instrument cluster, lcd, pixels |
