08-08-2021, 04:21 AM | #441 |
Rep 4
6WB issue
Hi all
Was there a fix for the error that BMWFanaticRob has/had? I've the same issue on a F36. Action done: Added 6WB to VO, connected MOST to HU-NBT & DKOMBI, Flashed the NEW 6WB OK, coded the DKOMBI with E-sys with status Green but VIN wasn't shown after DKOMBI i () ? Status is now RED Dot in 6WB / Cluster / DKOMBI and Serviceinterval is just '---' Is there like something that needs to be FDL'ed? Car is 16-07, coded HU-NBT and DKOMBI with 1703 where 6WB was released. |
08-11-2021, 07:50 AM | #442 |
Rep 692
Anybody with a 6WB updated cluster on f30 taken their car in for the 4G update?
Bimmercode best coding options (Basic and Advanced):
https://g20.bimmerpost.com/forums/sh...5#post29807925 |
08-16-2021, 05:43 AM | #443 |
Rep 275
has anyone managed to code 6wb so it shows navigation instructions in both the cluster AND the hud? I know by default it can only show in one or the other, but I see no reason to not display in the cluster too given nothing else goes there.
Also, is it possible to code to show the remaining range in sports mode without disabling it and always showing comfort?
Previous: 2002 E46 330i M-Sport (m54b30 LCI), 2007 E92 335D M-Sport Coupe (m57), 2003 z4 3.0i (m54b30), 2010 E92 325D M-Sport Coupe (n57 LCI), 2019 F36 430i M-Sport Pro Gran Coupe, 2018 F36 440i M-Sport Pro Gran Coupe MPPSK
Current: MY2021 M550i, Aventurin Red, Ivory Nappa, Comfort Pack, Tech+ |
08-20-2021, 12:02 PM | #445 |
Rep 1,813
08-20-2021, 12:25 PM | #446 | |
Rep 692
Skyhigh1886.50 |
08-20-2021, 01:26 PM | #447 |
Rep 1,813
i agree, the only thing i'm disappointed by is that the Sport gauges don't display the gear I'm in since i have a manual transmission, apparently it's only coded to show your gear if you have an automatic transmission. which in my opinion is an oversight by BMW.
09-13-2021, 10:11 PM | #448 |
Rep 384
finally, my Manual shift light indicator on 6wb is activated
very nice feature, cheap substitute for race display steering wheel https://www.instagram.com/reel/CTuVC...dium=copy_link now i know when to change the gear
Instagram: nightfall.f30
09-14-2021, 01:24 AM | #449 |
Rep 3,872
It is active by default, actually… at least for the factory 6WBs.
09-14-2021, 02:43 AM | #450 | |
Rep 384
its not active by default, confirmed with 320i, 330i build date 2017-2019 with 6wb from factory
09-17-2021, 05:57 AM | #452 |
Rep 2,302
09-18-2021, 12:53 PM | #453 | |
Rep 59
Regards |
09-23-2021, 10:02 PM | #454 |
Rep 136
Hi guys,
I added a new 6WB to my car. The 6WB itself is working. However, the NBT Evo that I added to my car a couple weeks ago is not working normally. The menu is off center. Anyone know what is going on with my NBT Evo? I have already tried the following codes: DISPLAY_VARIANTE -> breites_display CID_APIX_MODE -> apix2 CID_COLOR_DEPTH -> 24 CID_COM_MODE -> mii CID_RESOLUTION -> 1280 x 480 CID_DISPLAY_SIZE -> 8_8 DISPLAY_SIZE_RESOLUTION -> 8.8_1280x480 Thank you, |
09-24-2021, 12:21 AM | #455 | |
Rep 2,302
Someone has coded the NBTEvo to ID6 but ist has to be coded to ID6_light. Unfortunately, I don't know the exact values out of my head and can't look it up at the moment. But I'll try to find it quickly on the internet. HMI_ID_VERSION to id6_light If it’s not enough then still HMI_Version to ID5 |
09-24-2021, 12:49 AM | #456 | |
Rep 136
Thank you! That's it!
09-24-2021, 08:12 PM | #457 |
Rep 136
Hi guys,
I have one more question. The 6WB is working fine but I am not able to get the Navigation running on the 6WB. The coding on FDL is done: DKOMBI => NAVI_NBT_ENABLE = kein_nbt Anyone knows if I am missing anything? Please let me know! Thanks, |
09-24-2021, 09:18 PM | #458 |
Rep 136
I just disabled DKOMBI => NAVI_NBT_ENABLE and the Navigation shows up on the 6WB now. Does anybody understand why it is doing this?
09-25-2021, 02:56 AM | #459 | |
Rep 2,302
For the NBT Evo2 you have to set it to NBT_Anzeige. I don't know why but i experienced the same problem last year. |
09-25-2021, 08:14 AM | #460 |
Rep 136
09-25-2021, 08:43 AM | #461 |
Rep 136
I also tried to enable the compass by coding: kompass_graph_enable --> aktiv
No luck so far! Anyone has any idea on this one? Thanks for your help, |
