09-05-2021, 02:43 PM | #1 |
Rep 383
JB4 Honest Review (Stage 1)
Hi All,
Wanted to make a review of the jb4 even since I got it over 3 months ago. The only engine mods I have done to my car (n26 328i) is Charge Pipe and the tune itself. So right of the bat stage 1 is a noticeable difference now at first you can feel it almost instantly, but I will say after a month or two you forget about the power completely but Burger motorsports does claim that its a 25-40 HP gain from the stock boost and peaks at 22 PSI on stage 1 (correct me if im wrong). Now some people may hate this but it only kicks on after 50% throtl know if you think this is a bad think this might not be the tune for you, but for daily driving a car i think this is perfect because you don't need the power if you are not driving the car hard. Secondly, I prefer Jb4 over others because it wont be as dangerous when voiding the warranty as its not a ECU remap put a piggyback system that directly connects to the intake, turbo and monitors and tricks the system into making more power. Let me know if you have any questions or concerns and ill the best to help you out |
09-05-2021, 04:57 PM | #2 |
Rep 2,808
Drives: F33 430 and F39 M35i
stealerships can detect piggyback mods even after you removed them if they dig deep enough. I highly doubt all piggyback claims of their hp additions. do a stock run on a dyno, then do a run with your tune and measure the difference there.
i had a jb+ on my F33 for a few months and didn't like the way it randomly kicked in so I did a bm3 stage 1 flash (b46 engine). the increase was more linear and noticeable from stop. A few dyno runs showed it added about 23 hp. I didn't think to go to the dyno when I had the jb+. in my f39, I'm still under warranty and have the tdi piggyback box in it. i get another free oil change soon and I don't plan on removing it. the tech will see it and i frankly don't care if they note it in their system. they knew my f33 was modded and when my ecu broke, it was still replaced at no charge to me and i was able to reflash bm3 on it. |
alohasurftoad3075.00 |
09-05-2021, 05:02 PM | #3 | |
Rep 383
09-06-2021, 08:40 AM | #4 |
Rep 190,707
Here is a dyno with the difference with stock
there are hundreds of thousands of tuned cars, they all get warranty done, i don't think I have ever heard of a single case with getting caught after removing the tune. Congrats OP, glad you like the new tune
09-06-2021, 12:56 PM | #5 |
Rep 383
I appreciate the graph mike, is this on a stock car with just jb4 stage one or is there any bolt ons?
09-06-2021, 12:58 PM | #6 |
Rep 190,707
Stock car
09-06-2021, 01:00 PM | #7 |
Rep 383
09-06-2021, 03:03 PM | #8 | |
Rep 190,707
09-06-2021, 03:59 PM | #9 |
Rep 383
So im assuming if it was normal 91 pump gas we would be looking at around 280, I want to pull the trigger on downpipe but I have a muffler delete I don't want it to be that loud but I do have secondary cats sooooo...
12-23-2021, 07:26 PM | #10 |
Rep 48
12-23-2021, 10:54 PM | #11 |
Rep 383
12-24-2021, 09:11 AM | #12 |
Rep 190,707
the piggyback is a tune. You can run E85 with a piggyback only, keep your mix at E30 with a stock fuel pump.
12-24-2021, 10:47 AM | #13 |
Rep 48
12-24-2021, 12:00 PM | #14 |
Rep 48
i have a 2016 328i xdrive with the jb+ injen intake and Active Autowerke BMW F2x/ F3x 228/328/428 Signature Exhaust all from extreme power house.
So if I mix 70% 93 octane and 30% e85 I should see a nice power increase? does it usually take a tank before it picks up the extra power? about how much would you guesstimate I would make compared to just running 93 octane? Thanks for all the info |
12-25-2021, 03:05 PM | #15 |
Rep 190,707
If you are running E85, i recommend you get the JB4 instead and the flex-fuel kit for the best results.
mrphotoman0.00 |
12-26-2021, 08:24 AM | #16 | |
Rep 48
I understand the jb4 is an actual tuner where the jb+ is just increasing boost |
12-26-2021, 10:27 AM | #17 | |
Rep 190,707
So to answer your question, yes, you can make more power with the JB+ and E85; you also can run it without any issues, but you are doing so blindly, so keep the E85 mix very low. The Jb4 is the better option as you can make a lot more power safely since you can monitor the trims, and you can add more E85 if you have more room and make even more power. It also got a failsafe that will apply stock boost if the car runs lean. If this happens with a Jb+, you are going to run into a significant issue that might damage your engine it's just not worth it to save $200 on a lesser tune.
12-26-2021, 11:04 AM | #18 | |
Rep 48
12-31-2021, 12:36 PM | #19 |
Poor 4 series
Rep 23
Do your car a huge, huge favor. Don't start playing around with the Fuel mixture with a simple piggy back tune if its your daily driver. Your but dyno is barely going to feel anything, and your chances of damaging your engine go up exponentially.
