08-22-2019, 01:36 AM | #1 |
Rep 90
CEL came on immediately after purchasing a N57
I just bought a 2016 535D (I know this isF30 post but there was no N57 community in F10post) and as soon as I got on the highway the CEL was on. It wasn't on during the test drive, so it literally came on after I signed the papers. It had 51k miles and I bought it from a used car lot. It was a BMW fleet vehicle and then only had one owner. The good news is that I have 36k mile warranty.
I dropped it off at the shop and although I was expecting a simple "read the code" error, they fed me some bs about how they still had to diagnose it. So they said that the diesel exhaust fluid pump had failed. I am BRAND new to diesels and have not even heard of that. The car has been running fine (I have been driving it regularly and put probably a little under 500 miles on it). Now we are waiting for the part to come in. So what exactly is going on here? Should I be worried? Again, I'm brand new to diesels so I really have no idea. And while we're at it, I told the dealer that I don't know anything about diesels and if there is anything I should know. He said the only thing he could think of is Adblue but I didn't get what that was all about. Also, the HUD has gone missing. |
08-22-2019, 07:46 AM | #2 |
Rep 1,799
Sounds like they're taking care of the problem. Without the code list we won't know if they're changing the right things, but it does sound like it. I don't think you need to be worried, especially since you have warranty. Most of the emissions and an important fueling component have extended warranty on top, so you'll be ok.
08-23-2019, 12:28 AM | #4 |
Rep 90
08-23-2019, 07:05 AM | #5 |
Rep 1,799
B5 is 5% blend of biodiesel.
08-24-2019, 12:25 AM | #6 |
Rep 90
Today the shop said the DEF had gotten into the tank or something and so they will have to drop the tank to see if there if any DEF in there. They could be more confident when they talk to me (And they don't call me. I only hear from them IF I call them when I get off work. So I'm already tired and just want an update, and they don't seem to be able to explain it very well and confidently). I am not a dumbass when it comes to cars so dealers/mechanics usually can't fool me but with diesels I have no idea.
Also, this isn't a diesel specific mechanic. It is the shop directly next to the dealership. I'm starting to get a little worried. Is this a thing with diesels? Even so, at 52k miles? |
08-24-2019, 09:12 AM | #7 |
Rep 1,799
No it isn't a constant problem.
If someone put def in the diesel then that is a problem that was caused by someone. Is the def in tank idea just a guess? Do you have codes that you can post? I would take it to a BMW specialist and not just any mechanic, however.
08-24-2019, 03:54 PM | #8 |
Rep 90
Unfortunately it is too late to take to a BMW mechanic because since the light came on IMMEDIATELY after purchasing the car, the first thing I did was call the dealership that sold it to me. They told me to bring it in on Monday to have their mechanic shop look at it. So now it is being serviced by them.
I just called for an update and he said the tank it "sludgy" and whatever is in there is barely moving. He said he will call BMW on Monday to see if it can be cleaned or if it will have to be replaced. He is assuming that DEF has been poured in for fuel. |
08-24-2019, 04:30 PM | #9 |
Rep 1,799
That's a really bad scenario if true.
It will require the whole fueling system to be changed out.
08-26-2019, 07:16 PM | #10 |
Rep 338
Diesel exhaust fluid (commonly known as AdBlueŽ) is an aqueous solution of urea made with 32.5% urea and 67.5% deionized water. It is sprayed in a controlled manner into the exhaust gas flow through a Selective Catalytic Reduction (SRC) catalyst fitted to diesel vehicles to help reduce emissions of nitrogen oxides (NOx).
These cars use very little DEF and it only needs topping up every 9000 miles on my F31 335d. You should be able to check the level on your I-drive. Once it get to certain level you will get a warning to top it up. If you get to a dangerously low level the engine will go into limp mode and if you run out it simply will not start. You would have to be silly to get to that level. It is cheap but corrosive so be careful topping up and there are easy fill leak proof bottles available. If it has been added to your diesel the tank may be corroded inside. Also it crystallises so the fuel pump [high pressure and lubricated by the diesel itself] may well be damaged or prematurely worn as may the injectors. I would be insisting that BMW checked them all out on their dollar or extended your warranty for the fuel supply system components [they are expensive to replace]....... assuming of course that they accept they sold you the car with the cr*p in the tank. Other than that these engines are superb, reliable and powerful. Keep to the oil change programme and only use recommended fully synthetic oils / good quality fuel and you will be fine. I'm in my 3rd 35d engine, hundreds of thousands of miles all tuned to over 350+hp / 520+ lb/ft and scarcely a problem. |
