11-06-2021, 08:24 AM | #2 |
Rep 16,082
Beauty is in the eyes of the beholder. However, neither of those provides much protection for the radiator or condenser coils. That's why I did this:
If you stay with a black grille there are black screens you can use. |
11-06-2021, 08:55 AM | #4 |
Rep 9
Wow you have done a epic job. Any sharing post of more photos for your grill?
I AM 3GT
11-06-2021, 08:56 AM | #5 |
Rep 9
I got what you mean and that is totally right.
I AM 3GT
11-06-2021, 10:40 AM | #6 |
Rep 16,082
That's all I've got. I took apart the stock grilles, which are made of two pieces that snap together. I cut off the vertical slats with a multi cutter, put the two pieces back together, cut the aluminum mesh to size, glued it to the inside of the grille with silicone adhesive. On the bottom section I cut the mesh to size, wrapped the edges with this:
https://www.amazon.com/Edge-Trim-Bla.../dp/B00KG9BAY0 It's secured to the lower grille with plastic zip ties. |
11-07-2021, 01:19 AM | #7 | |
Rep 9
I AM 3GT
11-11-2021, 11:23 PM | #10 |
Rep 4,551
Drives: 2015 328d xDrive
Matte. Black cars need contrast.
NYC Bimmer259.50 |
12-05-2021, 10:15 PM | #12 |
Rep 1,641
If you like the slats, I imagine you could use the plastic mesh-like products and attach that behind the slats. What do you think, Is that possible?
