BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > F30 - Rear sway bar/sway bar link movement
      05-23-2024, 01:10 PM   #1
NThatch
Drives: BMW F30 320D
Hi all
I'm in the process of trying to locate the source of my suspension rattles/clunks/warbles. Honestly it's sending me crazy Should my sway bar and links have as much movement as they do in the below video?
https://youtube.com/shorts/TrBaCiO34...mjWSWBOUwriGPP
Thanks in advance!
danb19792316.50
      05-24-2024, 08:33 AM   #2
Wires
Drives: 2016 340i xDrive
Knee jerk says that isn't correct, but mine acts the exact same, so assuming normal!
      05-24-2024, 06:35 PM   #3
NThatch
Haha it just seems like it can't actually be doing much. It's reassuring to know yours' is the same, but maybe we're both fluffed 🤷
      05-25-2024, 09:49 AM   #4
Wires
My thoughts exactly!
      05-27-2024, 03:57 AM   #5
Hi all
Thanks in advance!
UK section here if you want to post in there also:
https://f30.bimmerpost.com/forums/fo...412&order=desc
The rear drop links are cheap; I'd replace them both just for peace of mind (use Moog from your local motorfactors) or get Lemforder/TRW via Autodoc
When does the clunking happen; when driving slowly or all the time etc?
Project: https://f30.bimmerpost.com/forums/sh....php?t=1982298
      05-31-2024, 09:33 AM   #6
Jvac
Drives: 2015 335i rwd
Rear sway bar is almost laughably thin and flimsy on the f30. It can't be doing much but the engineers must have put it there for a reason. I mean to say it's pretty weak right out of the box. Assuming everything is tightened to spec and not visibly damaged/worn, it's just weak as the norm
335i rwd auto, 2015 with m performance LSD and Dinan stage 2. Cts charge pipe, mad 5" stepped intercooler.
danb19792316.50
      06-02-2024, 11:09 PM   #7
casualDIYer
Drives: 340i xDrive M Sport
I'd say you're end links are at the end of their life. That seems like a lot of play compared to my car, which also uses the same spaghetti noodle of an anti-roll bar.
As for other squeaks, when was the last time you replaced any suspension components on that car? If it's been years, get them checked. BMW = a squeak timebomb.
