BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > AWE Tuning: the BMW F3x 328i/428i Exhaust Suite
      07-15-2016, 04:09 PM   #45
Josh/AWE
Josh/AWE's Avatar
562
Drives: F80 M3 Comp
Just replied to your PM, Rich!
      07-25-2016, 10:21 AM   #46
Josh/AWE
Josh/AWE's Avatar
562
Drives: F80 M3 Comp
The easiest way to go quad: the AWE Tuning 328i/428i Quad Outlet Exhaust Suite.
      08-15-2016, 03:51 PM   #47
Josh/AWE
Josh/AWE's Avatar
562
Drives: F80 M3 Comp
All you need is one cut.
Shown below is the bolt-on 3D printed cutting template we designed to enable the factory bumper to perfectly accommodate the 80mm tips of the AWE Tuning F3X 328i/428i Quad Outlet Touring Edition Exhaust.
Before:
After:
      08-15-2016, 04:48 PM   #48
m4rcus
Drives: 2013 320i: Sport, 6sp manual
[QUOTE=Josh/AWE;20415338]All you need is one cut.
Ever consider a cutting template for the 320i? Would be interested in a single side dual exhaust 328i AWE exhaust if I could cut the 320i bumper using a template.
      08-15-2016, 05:11 PM   #49
Josh/AWE
Josh/AWE's Avatar
562
Drives: F80 M3 Comp
Back when we developed for the F3Xs, yes, but decided not to. A dual outlet single tip configuration would have even be awesome. If one really wanted, I'm sure there'd be a way to maneuver the p-side quad cutting template with something to secure it in place while inverted in order to mark the cutting line... or it could be free handed.
      08-15-2016, 05:18 PM   #50
m4rcus
Cutting with a template scares me, freehand terrifies me. Paying almost $500 extra for an AWE 320i single exhaust when the 328i is available and better looking is a hard sale. Wish you guys would reconsider.
      08-15-2016, 05:23 PM   #51
Josh/AWE
Josh/AWE's Avatar
562
Drives: F80 M3 Comp
I was speaking hypothetically, of course -- "what ifs."
Maybe I'll push to get a 320 in and scan it.
      08-15-2016, 05:26 PM   #52
m4rcus
      09-27-2016, 10:52 AM   #53
Josh/AWE
Josh/AWE's Avatar
562
Drives: F80 M3 Comp
Cool
Great video by CK Motorsport showing off the AWE Tuning 328/428 Resonated Performance Mid Pipe and Dual Outlet Touring Edition Exhaust featuring 180 Technology® with diamond black tips!
      10-19-2016, 02:31 PM   #54
Josh/AWE
Josh/AWE's Avatar
562
Drives: F80 M3 Comp
Get more with four - the AWE Tuning 328/428 Exhaust Suite.
      12-19-2016, 09:16 PM   #55
M Smurf
M Smurf's Avatar
157
Drives: 2013 328i M Sport
Originally Posted by Andrew/AWE View Post
Many of you have seen that we have entered BMW. What you may not have seen - unless you’ve been to our website - is more specific information about the products we have brought to the table. So here is a healthy serving of what the AWE Tuning F3x 328i/428i Exhaust Suite is all about.
AWE Tuning has tapped over two decades of experience in performance engineering to produce the ultimate exhaust for the The Ultimate Driving Machine®.
Hundreds of hours of prototyping, engineering, research, testing, and daily usage evaluation has culminated in the AWE Tuning BMW F30 328i/428i Exhaust Suite:
  • Featuring 180 Technology™
  • Full 3” CNC mandrel bent system
  • Max gains of 13hp and 13ft-lbs of torque at the crank
  • Available as single side (dual tip), or unique quad tip option
  • Fitments for N20 and N26 Motors
  • Dual walled AWE Tuning branded tips, available as diamond black or chrome silver
  • Dyno-developed, street proven on the AWE Tuning in-house 328i
  • Crafted from T304 Stainless Steel
  • Engineered, designed and manufactured in-house at AWE Tuning
  • No Check Engine Light - Guaranteed
  • Perfect Fitment - Guaranteed
  • Featuring the AWE Tuning Lifetime Exhaust Warranty
The Options
The AWE Tuning BMW F30 328i Exhaust Suite is available as follows. Some fitments depend upon N20 versus N26 motor type, so be sure to check our simple N20 vs N26 guide to verify motor type.
  • The single side (two tips) axle back F3x 328i/428i Touring Edition Exhaust, featuring 180 Technology™
  • The quad outlet (four tips) axle back F3x 328i/428i Touring Edition Exhaust, featuring 180 Technology™
  • The F3x 328i/428i Touring Edition Exhaust + Performance Mid Pipe Package, available in both single side and quad outlet
  • The 3D printed bolt on marking template to turn a single side bumper into a quad tip bumper
  • The Performance Mid Pipe, independently
All F3x 328i/428i systems are outfitted with 80mm Chrome Silver or Diamond Black, double walled AWE Tuning tips.
Important fitment notes:
All products are confirmed to fit both RWD and X Drive vehicles. Quad option systems are not yet confirmed to fit M Performance rear bumpers.
About the system
The AWE Tuning Touring Edition Exhaust
The AWE Tuning Touring Edition Exhaust is an axle back system that leverages AWE Tuning’s proprietary sound cancellation solution, 180 Technology™, to produce the perfect exhaust note, drone free. If you’re unfamiliar with 180 Technology™, learn more through this brief 180 Technology™ video.
The AWE Tuning Performance Mid Pipe
The AWE Tuning Performance Mid Pipe is a key component in obtaining the perfect signature aggressive yet sophisticated note from the exhaust. This resonated piece removes the factory secondary cat (on N26 Motors) and replaces it with straight through 3” T304 stainless steel tubing.
Sound Perfection: AWE Tuning 180 Technology™
Perfect tone comes compliments of AWE Tuning 180 Technology™.
As exhaust gases exit the 328i/428i engine and flow into an AWE Tuning 180 Technology™ equipped resonator, they pass through strategically located ports, and into reflection chambers. Sound waves, carried by these exhaust gasses, bounce off the walls of the reflection chambers. By controlling the size and location of the ports and the chambers, we also control when the sound waves exit the chambers. The specific timing of when the reflected sound waves rejoin the main exhaust flow creates a one-hundred-and-eighty-degree out-of-phase sound wave that cancels out problematic frequencies. More on AWE Tuning 180 Technology in the tab above.
Photos
Availability.
The systems are available as I type, either online or through AWE Tuning’s global network of incredible dealers and installation centers, right here (put in your zip, find your local AWE Tuning dealer).
Questions? AWE Tuning BMW Performance Specialists await! 888.565.2257, performance@AWE-Tuning.com, or right here.
Thanks for reading!
What do I gain with adding the mid pipe to the system? I'd be interested in hearing the difference with and without the mid pipe. Thanks!
      12-20-2016, 08:47 AM   #56
Josh/AWE
Josh/AWE's Avatar
562
Drives: F80 M3 Comp
The mid pipe omits the unmonitored secondary catalyst and comes as a true 3" mid sections. It gives the 328/428 a bit more aggression and straight-through performance compared to the axleback when ran by itself -- most run the full configuration. Can't find much video of drivers running the axleback alone, aside from this (skip to 1:05, then 18:07):
Full system:
When applying the full configuration, there's no cutting of the stock system. Otherwise, cutting at the factory-placed "dimple" is required when putting on an axleback (FWIW). Hope this helps.
      01-20-2017, 10:00 AM   #57
Josh/AWE
Josh/AWE's Avatar
562
Drives: F80 M3 Comp
Happy to announce that with the arrival of 2017, AWE F3X Performance Mid Pipes and Touring Edition Exhausts prices have been reduced!
Find a dealer right this way.
[above] Performance Mid Pipe and Touring Edition Exhaust paired to an aftermarket catless downpipe.
      03-08-2017, 04:58 PM   #58
Josh/AWE
Josh/AWE's Avatar
562
Drives: F80 M3 Comp
A throwback to our friends at Helix with a post-installation vid of the quad tip Touring Edition Exhaust Exhaust.
Get yours through an AWE Dealer or direct.
      05-06-2017, 12:37 PM   #59
andrew12
Drives: 2020 M4 Competition
Anyone in the Denver/Ft Collins area have this exhaust on their f3x? I'm looking at upgrading the stock exhaust to the Touring Edition with mid pipe, but would like to hear it first. Sounds incredible in videos but worried it might be too loud for me.
      06-12-2017, 10:56 AM   #60
Josh/AWE
Josh/AWE's Avatar
562
Drives: F80 M3 Comp
Installation of the AWE 328/428i Resonated Performance Mid Pipe and Touring Edition Axle-back with diamond black tips via 3Zero3 Motorsports:
      07-12-2017, 02:41 PM   #61
Josh/AWE
Josh/AWE's Avatar
562
Drives: F80 M3 Comp
Rev'n the AWE 328i/428i/330i/430i Touring Edition Axle-back + Resonated Performance Mid Pipe paired to an aftermarket DP.
      09-14-2017, 03:41 PM   #62
Josh/AWE
Josh/AWE's Avatar
562
Drives: F80 M3 Comp
A 328i was equipped with a proper configuration in the form of an AWE Dual Outlet Touring Edition Exhaust featuring 180 Technology® thanks to EchoTune in Scotland!
      09-15-2017, 10:10 AM   #63
xroshx
xroshx's Avatar
Drives: BMW 320i F30
Before:
After:
rims?
      09-15-2017, 09:30 PM   #64
fate_f30
fate_f30's Avatar
Drives: 2014 Glacier Silver F30 328i
I think I'm convinced on this exhausted...
2014 GLACIER SILVER F30 328i * Wheels:18" VMR V801 Titanium Black Shadow * Springs: DINAN 1" Lowering Springs * Tune: BM3 OTS E30/93 OCT * Engine: Evolution Racewerks Catless DP/CP/FMIC * Intake: AWE S-Flo Carbon Fiber Intake * Exhaust: AWE Exhaust Suite + Mid Pipe * Go Fast Bits DV+ Diverter Valve * Plugs: NGK LI Plugs * Lights: Depo Angel Eyes W/ Morimoto HID's * Hood: Seibon Carbon Fiber Hood
      09-16-2017, 12:22 PM   #65
madmortar
Drives: 2013 BMW 328i M-Sport
Me too, I just need the $$$ haha
      09-17-2017, 05:26 PM   #66
fate_f30
fate_f30's Avatar
Is there any welding involved on this install or is it all clamps?
