BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > EUROPE (Continental) > Lambda error F30
      10-04-2020, 08:39 AM   #1
GeorgeKLT
Romania
Drives: BMW E90 318D LCI
Lambda error F30
Hi guys,
I have used bimmerlink to diagnose my car and found out 3 x errors regarding lambda.
You can see them in attachment pic but just to be sure I'm writing them here as well:
284E00 Lambda probe to Kat, signal Nernst voltage: interruption
283400 Lambda probe to Kat, heating control: interruption
282E00 Lambda probe to Kat, heating control: short circuit to positive
Should I avoid using the car until I fix the issue?
What negative effects should I experience if I continue to drive the car?
Car is a bmw F30 320d ED from 2015 (B47 engine)
      07-14-2021, 12:42 PM   #2
Bodygard
Bodygard's Avatar
Portugal
Drives: BMW 420d
Did you have any recall for your car? I have a 2015 420d b47 same engine and there's a recall about EGR, doing it next week. I also have the same 284E00 lambda error and dpf getting blocked, regen error...will let you know if it was fixed.
If not, it's probably the oxygen sensor going bad. It's a known problem in these cars...
      11-21-2021, 09:24 AM   #3
DnV
Drives: Bmw F31 316D
Originally Posted by GeorgeKLT View Post
Hi guys,
Hi George
i`ve have the same problems,do you fix it?
      11-21-2021, 09:25 AM   #4
DnV
How about you Bodygard? Any luck with the recall?
What i need to do to see if my car need a recall to?
      11-28-2021, 04:53 AM   #5
GeorgeKLT
Romania
Hi guys,
When I posted the topic here I also did it on the regional UK forum and provided the solution there but forgot to input it on this forum as well.
Here you go:
"Just to let you know, I have changed lambda sensor PN 13628570689 responsable for the error codes and the car behaviour has changed a lot.
The fuel consumption has decreased and also dpf regeneration doesn't happen as often as before I changed the sensor."
Cheers
