12-27-2019, 09:02 AM | #287 |
Not a new member
Rep 17
Thank you, already coded independent ambient brightness, now only thing left is to find out whether my no-line F30 has the necessary wiring to use the white LCI Leds as well after coding + LED module retrofit.
Bootmod3 Stage 2 | Catted Downpipe | Work in Progress
12-28-2019, 08:19 AM | #289 | |
Rep 2
Bmw ambient light
Thanks |
01-29-2020, 12:57 PM | #290 |
Rep 83
well i was trying to find out what those strips are.
I think its from a led profile bar, it has a plastic diffuser strip on top of it. So i ordered a set from aliexpress and tried. the one i ordered had the aluminium profile included, 5 x 50cm for 12 euro.. You have to cut the strip in half, have to find oud the perfect dimension, so still testing. i think its the same thing that the guy from ebay does and sells. Im sure there are better ones available after some testing, but this one will do just fine for me now. |
01-29-2020, 01:50 PM | #291 | |
Rep 14,113
Drives: G82 M4C X-Drive
https://rover.ebay.com/rover/0/0/0?m...2F173836148784
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
01-31-2020, 10:45 AM | #292 | |
Rep 51
Drives: BMW 530 xdrive
Can I do it with bimmercode? thanks ... |
01-31-2020, 11:49 AM | #293 | ||
Rep 14,113
01-31-2020, 04:21 PM | #294 |
Rep 16
Drives: BMW 325d f31
02-01-2020, 02:51 AM | #295 |
Rep 51
02-13-2020, 05:19 PM | #296 |
Rep 47
I was interested in ambient lighting for my new to me 2014 F31 and watched the YouTube vid to see what was involved. Next time I got in the car I noticed that the piece is already attached to the door panel, I already have the lighting package! the problem is they're so dim I never even knew they were there. I checked in the setting and they're at full brightness, but barely put out enough light to reflect off the door lever. Any options for juicing them up? Bimmercode?
02-13-2020, 06:37 PM | #297 | |
Rep 14,113
Hali_Mark16.50 |
02-17-2020, 10:40 AM | #298 | ||
Rep 47
I coded the ambient to be seperate from the interior lights, but that's all it did, it's no brighter than when the interior light wheel was at maximum. I have seen pics of someone else's result and it seems much brighter after decoupling. Mine are at 100% and can barely see them. |
02-17-2020, 06:46 PM | #299 |
Rep 67
Hi all, I bought the $55 ebay ones for my F30, and recently sold it for an F32. I'll sell someone the 4 strips. They were on the car for about a month. They weren't THAT bright, but I did like the look better than stock, especially on black interior.
03-05-2020, 06:13 AM | #300 |
Rep 41
https://www.ebay.co.uk/itm/Led-Ambie...72.m2749.l2649
I bought these and installed them a week ago on my f30 that already had ambient lights from the factory. Theyre cheap-ish chinese led strips that do actually glow very well, the only problem is how backwards the color scheme is. All the strips have two connectors that you plug into the existing ambient light plug, but you cant have them all the same color. The rear right lets you choose between red and blue, but the rest have the same color on both plugs. Both left strips only have blue, while the front right only has red. Very strange and idk if it has anything to do with coding? Anyone else have any experience with it? I'm considering buying a new set from someone else as having asymmetric ambient light is ugly imo, any recommendations? |
04-12-2020, 04:01 PM | #301 |
Homer Yen
130
Rep 76
Ambient Interior Light Mod – Let There Be Light…Strips
Hello Forum Members,
Just did this, so adding my contribution. But it's all been pretty much said before... Buy It Here: https://www.amazon.com/gp/product/B0...VOBJIEZO&psc=1 Youtube Video #1 (thank you Thic F30) on install/look: https://www.youtube.com/watch?v=B2NKvZv5-mM Youtube Video #2 (thank you Thic F30) on optional coding: https://www.youtube.com/watch?v=B2NKvZv5-mM I own a pre-LCI 335i. Truth be told, I didn’t even know that I had any ambient lights hidden within the cabin doors until I came upon that YouTube video. The BMW lighting engineers must have completely underestimated (by a factor of 1000) the level of luminescence required to trigger the ambient “cool factor”. The pre-LCI’s ambient lights are just incredibly dim (which is why I had never even noticed that the car had them). When I saw the YouTube video, I literally ran out to my car, turned on accessory mode and the parking lights, and then had to look (per the video) to verify that there was indeed lighting there. Whadyaknow? That was a complete surprise to me. I then knew immediately what I had to do. And, I am now excited to be a member of the Ambient Light Mod Club. Some quick thoughts (beyond the opinions of that vlogger): 1. The lighting effect seems consistent from one end of the strip to the other (the various YouTube videos don’t really convey that). I was concerned that lighting along the plastic strip would be uneven, but the look is clean. 2. Because the ambient lights are dim to begin with, these strips can only amplify the light so much. You’ll probably say, “hey, that’s cool.” But, you won’t say, “WOW!” 3. Among the plethora of interior mods you can perform, this one (considering the low cost / easy 10-minute install / visual appeal) provides good value for the impact. 4. In the daytime, these aftermarket strips are pretty unnoticeable. I measured barely 2 millimeters of plastic that shows itself and I doubt that even the most discerning owner would even notice. See pic below of my passenger door with the plastic strip attached. You can see the nighttime effects in the previously mentioned and several other YouTube videos. Hey, what a simple and elegant upgrade! This enhancement is not only inexpensive but universally lauded by those who have invested in it. And I too now am a fan. Mod On! |
04-17-2020, 09:49 PM | #302 |
Rep 63
Are these the aftermarket light LED strips you are looking for?
https://amzn.to/2KdErd1 |
11-10-2020, 01:21 PM | #305 | |
Rep 4
11-11-2020, 02:32 PM | #306 | |
Rep 240
Did you notice any significant differences between the actual optical conductors with regards to either finish, shape, or anything that would lend itself to a brighter light being emitted from the strip? I always thought all optical cables were essentially the same; however, maybe I'm wrong. |
11-11-2020, 03:12 PM | #307 | |
Rep 16
zibbit
You just quoted answer I my case Quote:
