05-01-2020, 12:57 AM | #3279 | |
Rep 551
https://f30.bimmerpost.com/forums/sh...postcount=1041 |
05-01-2020, 06:50 AM | #3281 | |
Rep 43
The problem is when i use Wi-Fi or 3g connection in same time with gps! IT can be the fuse? Maybe is to low or high, or the battery of the car? If i remove the main unit it work perfectly |
05-01-2020, 08:29 AM | #3282 |
Rep 551
b777rky
Install this program on your unit = DO NOT LAUNCH IT AT THE END OF THE INSTALLATION Connect your phone in WIFI connection sharing mode with your unit Check that your unit is well connected to the internet with the Chrome browser for example Launch the application and wait to see if it also causes a "NO SIGNAL" message yes or no? https://www.cjoint.com/c/JEbnDhR7AcN |
05-01-2020, 10:45 AM | #3283 | ||
Rep 10
I've followed marakech process, but I don't know how to put my Px6 in recovery mode. I saw on PX5 that it is necessary to unsold a component. How did you succeed to unbrick pour px6 ?
PX6 4-32 - Android 9
05-01-2020, 11:54 AM | #3284 |
Rep 3
Problem between Zlink (v: 3.5.40) and widescreen
Greeting,
I have an Android 9 navigation system (MSM8953) with a 1280x480 widescreen, and when launching the Android Auto application through Zlink (v: 3.5.40) it is not seen in full screen, only in 4: 3 format. I have enabled AA developer mode for 1080p compatibility, but the problem persists. Please, do you have any ideas that can help me? Thx The best regards. |
05-01-2020, 12:38 PM | #3285 | |
Rep 87
05-01-2020, 02:44 PM | #3286 | |
Rep 30
I am almost sure that by flashing it you can return from 10 Android to 9 Android. I didn’t check it myself ... |
05-01-2020, 03:45 PM | #3287 |
Rep 399
05-01-2020, 03:50 PM | #3288 |
Rep 30
05-02-2020, 02:05 AM | #3289 | ||
Rep 551
my response to your private message Hello, Unfortunately once the PX6 in BOOTANIMATION mode which does not change and leads to nothing (infinite) there is only one solution: disassembly of the post / disassemble the rear part of it, remove the OTG protection from the USB chip on the motherboard (must find it!) follow the tutorial from MARAKEH (complex) And finally, reweld the OTG part ... I dropped and I was lucky that my reseller (of the unit) took back my PX6 against refound. In summary: I did not succeed and I changed my Android post. Good luck ! Quote:
This concern can also occur with TASKER in the background of the task which prioritizes its actions by slowing down the system. ABOUT TASKER: Has anyone here NOT OPTIMIZED the battery (applications) in the choice of our units ? I never found this option ... Last edited by F20_M135i; 05-02-2020 at 02:26 AM.. |
05-02-2020, 04:14 AM | #3290 | |
Rep 43
Yes, it gives me "no signal", i follow your steps, what can i try now? |
05-02-2020, 05:35 AM | #3291 |
Rep 551
This application (GPS TEST) does not change its function to call the internet connection even when it is detected.
If this application works correctly WITHOUT THE INTERNET CONNECTION The concern you encounter is a conflict between GPS and INTERNET in the exchange of flows, identifying this problem in hardware or software is an engineering matter. At your stage I will stop and ask my seller for a credit, then I will go to another ANDROID car radio Sorry |
05-02-2020, 04:24 PM | #3293 |
Rep 79
05-02-2020, 11:51 PM | #3294 |
Rep 71
CarPlay app has its own settings, play with the app you would find out how to change it.
Gabo
05-03-2020, 04:57 AM | #3295 | |
Rep 551
05-03-2020, 07:31 AM | #3296 |
Rep 30
05-03-2020, 02:08 PM | #3298 |
Rep 87
Yes I have tasker running from system startup. Did you manage to find the solution?
05-04-2020, 01:59 AM | #3299 |
Rep 3
05-04-2020, 02:30 AM | #3300 | |
Rep 551
by clicking on the icon at the top right of TASKER, you have the choice to "deactivate" TASKER for the next start. I therefore invite you to choose this option, then to restart your unit: if the 5 to 10 second pause disappears on restart (from action and menu), you should try to add a "minimum 3 second pause task" to your "startup profile" in your TASKER settings this should disable tasker priority on the launcher |
twoface52.50 |
